I've looked around the forum and other places to try and find an answer but I just don't get some of the mass information.
Thank you in advance for anyone who can help.
A projector that is rated to project it's image on a 50''-200'' screen. I'd like to increase this greatly (while maintaining the image quality/contrast/brightness if possible).
1: I could just move the projector back and focus it properly?
2: I would lose brightness and contrast in doing this?
3: 2 could be corrected with a different lens(maybe only fixing the brightness or contrast, and altering the throw ratio)?
4: Are there any non theater (4kx2k <$50000) projectors I should be looking at, that are still capable of 1080p (or better) and 3d(120hz)?
5: Does the projector lamp have anything to do with throw distance, or only brightness/contrast?
