I'm having problems playing MKVs in Windows 7 x64 using MPC-HC x64 or x86 (pretty much any version number).
The MKV will play fine until I fast forward/skip ahead to later in the movie; then the file will play too fast. The audio will also play too fast (meaning everyone sounds a little like Alvin and the Chipmunks).
I've noticed that this only seems to be a problem when using AC3/DTS passthrough (ie, when I uncheck AC3 and DTS in Internal Filters > Transform Filters). When MPC decodes AC3/DTS itself, both the video and audio play at the correct rate after fast forwarding. But I need the passthrough to watch MKVs over my receiver using HDMI.
Any suggestions? Am I missing a setting or something? Thanks in advance...
P.S. My laptop specs are: i5 520m, ATI Mobility Radeon 5650, and 4 GB of RAM. The problem occurs using both the dedicated ATI GPU and the built-in Intel GPU.
