So I've been trying to figure this out for weeks now and am stumped. I'm hoping that someone on here can help me find a solution to this problem. It appears that I'm doing everything right, but I'm obviously missing something.
What I'm trying to do is load an ISO using either Daemon Tools or Alcohol 120% and then play the file with either VLC or PowerDVD 10. These are all Blu Ray rips that I'm trying to play back and they all should work just fine. When I mount the ISO on my virtual drive (I
and it autoplays in either VLC or PowerDVD, I get an error.
This is the error I get from VLC:
Your input can't be opened:
VLC is unable to open the MRL 'dvd://I:\\'. Check the log for details.
This is the error I get from PowerDVD:
There is a disc with an unsupported format in drive I:
I would appreciate any help I can get on this topic, as I have searched through forums and google for an answer to this with no luck at all.
and it autoplays in either VLC or PowerDVD, I get an error.This is the error I get from VLC:
