Originally Posted by stgdz
christ 115db, my ears start to hurt at around 100dB with these big ass speakers.
also for the for the people running dual woofer setups are you going active or passive with your crossovers? I have been in phase alignment hell with my dual woofer econowave SR in PCD. I can get them really close but one of the woofers spirals out at above the crossover point for some damn reason.
How are you running dual woofers? 2.5?
With the 2352 horn, I'll be able to cross around 800hz and run it 2-way TMM. If I ran it 2.5 way with a smaller horn (ie SEOS or QSC) there would need to be some major CD attenuation because the top woofer would be operating closer to 16ohms. It is certainly possible but I've never designed a crossover like that myself...that is assuming an 8ohm CD. If you get a 16ohm CD it should be pretty standard.
Do you have a link to your project where you are having trouble? I'd like to toy with it in PCD to see what I get.
