AVS › AVS Forum › Video Components › Home Theater Computers › Silent stream bug?
Silent stream bug?
post #1 of 109
AVR Audio Guard
Download at www.marcsapps.co.uk
AVR Audio Guard is a Windows program that fixes the "Silent Stream Bug" that
affects many owners of Audio Devices attached to A/V receivers, especially those
with Nvidia High Definition Audio devices on their Graphics card.
Formerly known as AVR Audio Switch Fix, I recently made huge changes to the
way the program works so that it is more responsive, less system intensive and
far more resilient. I felt that after effectively rewriting the entire program, since
the code was all new, the name should be too.
So AVR Audio Guard  was born, and you can find it on my new site:
www.marcsapps.co.uk
If you like the program, or the site, please click the "Like" button in the top
right corner of the site to spread the word among your Facebook friends.
Please note: because the site is new, some over eager AV/Firewall products
will warn you that the downloads may be unsafe, but they are perfectly fine.
Edited by MarcD2K11 - 6/10/12 at 7:09pm
post #2 of 109
I was using the "ati anti pop" app from the slysoft forum. I think it did something similar to yours to stop the constant click of the receiver.
But SP1 seemed to fix it for me so I stopped running it.
post #3 of 109
ah yes, didn't know someone had already written something, not very obviously named is it?
he says it only works for ATI cards so perhaps mine will still be useful for people with Nvidia cards.
post #4 of 109
I think SP1 only made my situation a little bit better.
I get to hear a few more syllables.
GeForce GTX 460
Onkyo TX-NR1008
post #5 of 109
Thank you for this program! This fixed the most irritating issue of my htpc setup. I was going crazy with the source selector constantly switching withs it's pop noise with windows sounds.
post #6 of 109
glad you found it useful It's had 20+ downloads so far and you're the first person to say anything so i wondered if it actually worked for anyone else!
post #7 of 109
Oh yes, it works fine! Thank you very much!
post #8 of 109
THIS IS A GREAT FIX! I can't believe this solution isn't more publicized. This problem had been bothering me for a while, I finally decided to do something about it and like other people with NVidia cards, the SP1 update did not help my problem.
Way to go! Thank you for the fix.
post #9 of 109
Hey MarcD2K11! Thank you for your work! If you don't mind here's a little feedback and few wishes
The one problem with your program is that it doesn't resume its function after I switch on/off the TV which is hooked up to the receiver (in this case both displays start blinking, as if I connect another monitor. The sound is interrupted too). It keeps sitting in the task bar but in fact it doesn't work. Maybe it's possible to implement some kind of mechanism to detect when the silent stream was interrupted and restart it automatically? Or kind of button "Restart"?
And also would it be possible to put in in System tray so it won't take up the space on the task bar?
Thank you again!
post #10 of 109
Sorry to bump an old thread.
I am an Nvidia user with this very issue. Is there any solution to it?
I just downloaded the app, seems to work great - thanks. However, is there a way to force it to tray instead of constantly having it on the taskbar?
post #11 of 109
You can make the app run as a service - however, I am not sure if you can keep it as a tray icon or not - but at least you could access it through the normal Services interface. Another advantage is that it can run even before you login!
An example:
http://serverflux.com/windows-tutori...ystem-service/
You can also google around for plenty of (old?) examples of converting an app to a service that is always running.
post #12 of 109
An example:
Figured it out by using "Trayconizer". Works like a charm. Problem is now that the audio device changes I have to restart the program... Ugh
post #13 of 109
this is a link to my more recent build, with a reinitialize button to allow you to restart the silent stream if it gets interrupted by turning off your tv or changing sources on your receiver. When i get some time i'll look at adding tray icon functionality
link deleted - most recent link is now in post #1
post #14 of 109
http://www.mediafire.com/?ryx7tlvipnlsxp2
Thank you.
Are you willing to share the source code so I can edit it to my likings if I have to?
post #15 of 109
yeah i suppose so, there's nothing particularly complicated in it. I wanted to get it to detect when windows was using exclusive mode (bitstream) but that's way above my level..
post #16 of 109
Where can I find the code :-)?
post #17 of 109
i'll upload it later on, i'm just working on a new version of the program at the moment. Have it running in the tray with a context menu and a re-init hotkey now, just changing the icons to make them a bit more visible for the tray and then it'll be uploaded
post #18 of 109
You should be able to catch the audio device change automatically too. Doesn't sound like something too hard. Then you could automatically re-initialize it.
post #19 of 109
updated version of the program now available via the link in post 1
it's changed a fair bit It's now solely in the system tray with different icons for better clarity and has a context menu if you left/right click on the tray icon which includes the re-initialize function among other things. Check out the readme included with the new download for all the information.
post #20 of 109
Good stuff Marc! Maybe in the future you can consider making it a service, so that when you boot the PC it'll be running in the background before you login? That way, we can have our fancy-pants login sound! :P
post #21 of 109
i think i tried that first time around and it didn't work because of when the audio services start, but i'll certainly have another crack at it
post #22 of 109
I think there is a way to prevent a service from starting until another one it is dependent on starts first. It's been a awhile since I looked at it hehe.
post #23 of 109
It was deleted, I need this...
post #24 of 109
Hi
for anyone coming here from the Denon thread or elsewhere, the link to the current build of the software is in post #1
post #25 of 109
The problem is still here after two generations of cards...
My new GTX 670 still has it...
post #26 of 109
Yeah it's still there - one time I thought I had it fixed, but it turned out to be a hidden video in the browser that opened a sound channel! :O
post #27 of 109
I should have a new beta version available in the next day or so which totally changes the way the program works, finally using the methods i wanted to use.
Changes:
The app list is now redundant, and instead, thanks to a fantastic open source audio library called naudio.dll, the program will detect when a WASAPI exclusive mode stream has taken over, and will kick back in when the WASAPI stream ends. It also detects when the sound device it's playing on is disconnected so if you turn off your tv/receiver it should kick back in once they're turned back on.
Still to do:
I haven't implemented running as a service yet because you can't have a GUI on a service so it'd mean having two seperate programs. Now i've more or less sorted out the main program it should give me some time to start working on that..
Due to the massive nature of the changes, I could do with a few people testing out the beta before i release it publicly to make sure it isn't just my own pc it works on. If you're interested, send me a PM and i'll link you to the file once i've compiled it. If you do try out the beta, please let me know if it works for you in the situations described above, or if you encounter any bugs.
Marc
Oh, i'm also thinking of renaming the program to something that's less of a mouthful.. any suggestions?
post #28 of 109
Cool, I will gladly test it when it's ready!
How about calling it: NVDIASucksAtStreaming? Or: FixAStupidNVIDIABug Or: SilentStreamConfabulator?
post #29 of 109
thanks to maxleung and lindrian for testing the program i will be going live with it soon but there will be a bit of a delay because i've set it up with a clickonce installer so that if i do updates you'll get them automatically, so i'm going to set it up with its own webpage.
I've been thinking of names and i settled on AVR AUDIO GUARD - because i figured like an AV Guard prevents unwanted viruses, my program prevents unwanted audio switching (so perhaps AVR SWITCH GUARD is another option).. opinions?
post #30 of 109
Heh that's a cool name.
The program seems to work well, with the exception of ASIO but ASIO is .... strange, and it may be particular to my system using NVIDIA HDMI audio.
