Originally Posted by James Sponaugle
Can the BD670 be coaxed into playing mkv's remuxed from DVD (e.g. plain old mpeg2 +AC3 content)? It seems my 670 (with latest firmware) just won't do it (over the network...never tried on USB, and don't plan to). I saw a couple of tips here in this thread about making sure header compression was turned of (by remuxing with mkvmerge), which I did, and that didn't help. It's still saying it's an unsupported format. I've used makemkv and DVDfab (using passthrough mode to an MKV container). I've re-encoded to some other lossy codecs and that seems to be ok though. Raw mpeg2 work fine of course, but I'd really like to have chapter stops. Are there any other containers the BD670 supports that could give me chapter stops and that support mpeg2 payload remuxed straight from DVD? I'm starting to think they don't want me to play my dvd's without re-encoding
.I haven't done any experimentation with chapter markers myself, but mpeg2 inside mkv seems to be pretty non-standard. I mostly use mpeg2 in either, .mpeg, .vob or .TS files and use Serviio as my DLNA server (a DLNA server is necessary for .vob support and perhaps for .TS support). I'm assuming you've already tried .mpeg which is the only container natively supported by the LG which is commonly used for mpeg2.
One alternative to chapter markers may be to split them into separate files. This won't give you seamless playback (the player will buffer between files) but at least you can start at the beginning of a chapter that way and you don't lose any quality as you would when transcoding to a different codec. I transfer a lot of content from my DVR, edit out commercials, then save each segment as a separate file. In this use the buffering only occurs where the commercials would have been, so it doesn't bother me. Wouldn't want that if I was watching a movie, but it's something to think about.
Note: you can probably get your files to play using a DLNA server like Serviio, but it would remux the files to another format in which case you may lose the chapter marker functionality.
