AVS › AVS Forum › HDTV › HDTV Technical › What's the difference between these antennas?
post #1 of 11
post #2 of 11
Well, the thing that is similar about them is that they are both two-bay bow tie UHF antennas. Performance and construction may differ somewhat, though.
post #3 of 11
hn333, I can tell you firsthand, the build quality of the Eagle-Aspen is excellent. It is a great, sturdy outdoor UHF antenna, if UHF is all you need. I have purchased several of those in the past. Some antennas from antennas direct are also good, but IMO, many are overpriced, including the one you linked to.
post #4 of 11
Originally Posted by hn333 View Post
Other than the price
The difference is that the cheaper antenna is below the threshold for free shipping.
You did need a splitter and a jumper cable too, right?
post #5 of 11
Thanks for the feedback. Looks like just the antenna I need.
post #6 of 11
What's the difference? The difference is a non-specific topic title will get fewer responses.
Topic title edited.
post #7 of 11
The difference is that anything that says Antennas Direct on it has a 40% markup just for the name.
post #8 of 11
Have you checked to be sure there are no VHF channel allocations in your area?
BTW...if there are no DTV channels on VHF, you might want to purchase a small FM antenna (yagi or omni-directional) and a diplexer. That would get you up there in the "free shipping" area.
post #9 of 11
I only have one VHF channel in my area.
post #10 of 11
You may not get the VHF station with the DB-2.
post #11 of 11
They are both very similar. I think there is mainly a bit of a difference in the balun, but not sure how this effects reception of specific channels. Perhaps DB2 not as good on VHF.
  Back to Forum: HDTV Technical
