Actually, there has been a way for many years, and that way is posted here with the files posted here...
However, what is fairly new is a way to update the Comcast DTA codes without having do anything more than simply change your 5040's network configuration temporarily so that you don't have to install any special software at all! That method is posted here...
In addition, if you happen to already be using WiRNS, then you can simply install a package for WiRNS to install the Comcast DTA update as well, which is posted here...
