This the first of what I'm sure will be many posts to these forums, so forgive me if I'm posting my questions in the wrong area. I'll learn eventually
Since there are so many similar threads, I'll try to make this question very specific. As a quick background, I'm just starting to finish my basement. The plans are not set in stone, but I'm pretty comfortable with what I have laid out. I plan to start cutting 2x4s in about 3 weeks.
OK, to the point. My goal is to install the biggest screen possible within the parameters of the allocated space. I understand there are many factors involved, but I'll supply as much information as I have and will answer all clarifying questions.
First, here is a 3D view of the space with some dimensions, then a plan view:
Here are some data points/assumptions that I'm working with:
Well, that's all I can think of for now. Again, I'm trying to establish the largest screen I can install. Specific product recommendations and/or technologies are certainly welcome.
Thanks AVS for being such a great resource!
- Projector: Undefined. Considering a $3K max, but would obviously like a lower priced unit if it meets my needs
- Speakers: This is a whole other issue, probably for another forum, but it affects the screen size since I need room for the speakers. FWIW, since I'm building the wall that the screen mounts on, I would consider behind-the-screen speakers (not sure if these are poo-poo'd here or not
) - Screen: I'm assuming some sort of pre-manufactured screen. I'm pretty much a noob when it comes to gain/color/texture/manufacturers
- Seating: I chose some Berkline seats. Family of 4, ma & pa in the love seat (makes wife happy) and kids (two boys 7&10) in end seats. If we have more people, they can pull up chairs/beanbags/etc. and they'll have to deal with the crappier view
- Lighting Control: One window, I plan to install some sort of blackout curtain. Otherwise total lighting control. There are several likely scenarios (parties, sleepovers, etc.) where there will be ambient light from adjacent rooms, but this will not be a "critical" viewing situation, so I'm not too concerned about slight picture degradation.
, try different size/shapes (AR) screen formats before you commit.
. I didn't plan on spending 5 hours of my Sunday re-designing my basement, but I'm really happy with where it went. More importantly, my wife is happy too!
