Originally Posted by
bloozeman
Playing video games with or without static images is not misusing, abusing, etc. a display unit of any technology.
You can't play games on plasma TVs for hours at a time when the game has stationary graphics on the screen without risking or even achieving permanent image burn. The pixel rotation feature will NOT stop image burn, it will only soften 3 or 4 pixels around the edges of the stationary graphics. Pixel rotation is better than nothing, but it's no protection for accumulated hours of gaming where there are stationary graphics on the screen. If you keep doing that, you WILL turn your current minor problem into a much more visible and PERMANENT problem. That is abusing a plasma display whether you think it is or not. Plasma displays CANNOT be used for hours of gaming with stationary graphics on the screen without eventually permanently burning the image of those graphics into the screen. You cannot change this by denying it.
bloozeman
I have been doing just that, i.e. playing the Blu-Ray release of GoodFellas (which is a 1.85:1 aspect ratio and fills the screen completely without the need of any stretch modes) on a continuous loop over a couple of nights this past weekend.
The aspect ratio of your screen is 1.78:1 not 1.85. 1.85 movies do not fill the screen if you are in 1:1 pixel mapping mode, there will be small black bars at the top and bottom of 1.85:1 images if the TV is in 1:1 pixel mode (called dot-by-dot and a few other names).
bloozeman
The point of my original post was that I am pretty confident that if I had been a bit more careful during the break-in 200 hours by leveraging the built-in erase pattern in between each Black Ops online match I would not even have the amount of IR I have today. Plasma is just new to me and I would not even have it today if my Pioneer Elite 630HD had not died on me last year. The 630HD, being a RPT, was susceptible to burn-in as well so I have always been cognizant of the issue but like I said just not as diligent as I should have been. I knew from the onset that LCD would be a safer bet from an IR perspective but I chose plasma over it due to plasma's potential for producing better (native) contrast ratios and deeper black levels.
Plasmas are a bit more sensitive to permanent burn-in early in life, but it really doesn't last more than 50 hours or so - and it's difficult to quantify how much more susceptible to problems they are when "fresh"... maybe 10% or 20%, probably not more than that. The B&W phosphors in 3-CRT RPTVs are much less sensitive to image burn than plasma technology. I'd guess it would take double or maybe even more than double the hours to burn an image into the B&W phosphors in the tubes of a CRT projector (rear or front) compared to plasma. That's why plasma displays are really not a good choice for gamers who accumulate a lot of hours.
"Erasing" retained images (after-images that disappear over time are image retention issues, after images that never go away are burned-in) takes about as long as the content that caused the retained image. So if you were gaming for an hour, it takes about an hour to erase the retained image. So gaming for, say 3 hours with three 10 minute breaks where you run the erase pattern means you need at least 2.5 more hours of time away from the stationary graphics. Personally, I think 3 hours of gaming with a stationary graphic on the screen all the time could put you pretty close to having either permanent or at least have a "strongly" retained image that takes quite a lot of time to completely erase. Then there's the issue of accumulated damage... let's say you have something stationary on the screen for 2 hours. You then watch a movie or TV programming for 2 hours, but there's still a bit of retained image. But you go back and do some more gaming before the previously retained image is completely gone. Now you are starting from a "bad" point and the next 2 hours is going to make the retained image even worse and lengthen the time it takes to completely get rid of it. If you keep going back to the same game with the same stationary graphic before it is completely erased, you are accumulating more and more damage and, over time, it WILL become permanent even if you never had a single gaming session that was particularly long. It's this issue that makes plasma a bad choice for anyone who games regularly (with the same game and same stationary graphics all the time) and plays for more than an hour or two at a time. Not many people will admit you can damage a plasma panel in this way, but I have seen too many of them with "game damage" for there to be any question about what's happening.
It's nice that replacing the panel isn't an issue for you if it is "burned" enough to be annoying. But most people (for whom a $2000 or $3000 TV is a big purchase) don't understand just how easy it is to permanently damage the screen by getting caught-up in a few gaming sessions without enough non-gaming time in between to fully erase the retained image. And it's not gaming that's really the problem, it's the stationary graphics. I've played many games that are more "cinematic" and have no stationary graphics... those are no problem at all. You can play those types of games endlessly and not have problems. TV programming with stationary graphics is also an issue... news channels and sports channels are prime offenders, but The History Channel ought to be pilloried for their over-bright and over-present channel logo.
