Originally Posted by blazar
http://www.rpginc.com/products/flutterfree/index.htm
this is the site with the diffusion graphs for the material that I used on the doors. Do you think this would be bad behind the listening position necessarily?
im merely trying to draw attention to the fact that sound has size and diffusers need to be of certain physical size to be 'seen' by relevant wavelengths.
i would not recommend spending large sums of time and money on "diffusers" that are only seen by HF wavelengths of which have little energy content to begin with. in the case of QRDs (like what appears to be N7 QRDs on your door), the wells are so shallow that the diffusers on the door are not going to be "seen" by any relevant mid-band energies! no diffusion will take place - those wavelengths will not see the highly complex well pattern on the door...they will simply see and reflect as if the door were a flat boundary.
again, i would seriously consider taking a brief moment and read the QRDude technical guide. even if you are not building Schroeder diffusers based on Quadratic Residue number theory, it helps to understand some of the foundations for such devices.
if you want to see a room with true "diffusion everywhere" - i suggest investigating the Ambechoic acoustic model of Blackbird Studio C (http://www.google.com/search?tbm=isc...l939l1.5.1l7l0)
you'll notice how deep the diffusers are in this extreme example, as sound has size and the diffusers need to be of sufficient physical dimensions in order to properly diffuse such low-mid frequencies. it may also shine some light onto those who think "diffusion everywhere" may create too live of a room - as the first order reflections are attenuated by the diffusers by -30dB!
if you're really interested in diffusion everywhere within your room, it may be wise to take the time to understand how "diffusers" actually diffuse (temporal and spatial dispersion) sound, the limitations, design constraints, and the relevant physical dimensions that must be adhered to in order to meet your design criteria.
regarding polys, which can be useful in larger (relative) home rooms (and more affordable), there really is much design work that needs to be taking into consideration. some additional insight:
http://www.gearslutz.com/board/studi...er-thread.html
http://www.gearslutz.com/board/studi...ion-polys.html
http://www.gearslutz.com/board/bass-...i-y-polys.html
http://www.gearslutz.com/board/studi...er-design.html
