I've seen mentioned multiple times that a center channel that is the same as your left and right mains is the best way to go if you can. The rationale given is that the center is often a compromise to make the drivers, sometimes with a smaller mid, fit in a horizontal array using an MTM setup. However I'm wondering if there are situations where a separate center channel is a better option (for reasons other than cosmetics).
I'm thinking of reasons like off axis response, horizontal dispersion, etc. One of my main viewing positions is outside of the left speaker, so I'm not always in the sweet spot.
My question is more of a general one, but for those that want specifics, I have NHT Classic 3s as mains, and can fit a third as my center. The Classic 3 Center is not the typical MTM setup though and is a very nice center from what I've heard. Drivers and sensitivity are essentially the same - although the bookshelf is rated a tad lower in FR.
