Originally Posted by wopino
just got my LN32D550 yesterday, set it up and connected it to my pc via dvi-hdmi and it has a dead pixel on the lower right which doesn't bother me at all because it is barely noticeable, however, what does bother me is the yellowish tint it has on light color field right in the middle of the screen spanning the entire middle from top to bottom. For instance, i was checking my yahoo email and it is definitely noticeable as the middle of the screen was tinted yellow/brownish. It seems it might be the coating on the screen or something because the problem seems to shift as i move off center, but when looking at it on center it looks bad...the main purpose is for a pc monitor so this one will have to go back. Anybody else noticing a weird color tint on an all white background??
Perhaps it is just bad unit? Can you test it at the store with the display moedl? Also was it SQ01 model?
Did anyone test its lag input?
