I took my Antennas Direct 91XG outside and put it on a pole that I was holding on while my TV was scanning for stations.
and I was able to get 22.1 from WB with a 49-50 signal
My 55 inch Plasma also picked up 49.1 and 50.1 butttt with no picture.
I am sure I can put a roof mount on my roof that I have and get at least another 10 feet at least...Would you good folks think I will get more stations?
and is it best to uut a Amp on???And what is the Best Amp I can get?
From the TV too the antenna will be less then 100 feet.
Since I am only facing the WB Scranton area I feel I don't think I need a rotor unless you folks think differant?.Thanks JT
