AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Wilkes Barre, PA - HDTV
Wilkes Barre, PA - HDTV - Page 24
post #691 of 701
The 7084 shows 131 inches long....so 11 feet
The 7698 shows 168 so 14 feet long
The HBU55 shows 145 inches so 12 feet long
The big difference is the 7084 is 110 inches wide (so 9 feet) due to the long elements for channels 2-6
The 7698 shows 53.5 inches so a little over 4 feet wide as it only needs for 7-13 which are much shorter elements
The HBU55 is about the same width as the 7698
post #692 of 701
Just ordered a AntennaCraft-HBU55 for $95 with shipping
I felt the price and reviews were good on the antenna.
Feel this antenna will work well and if I need a amp then I will get one.
But for now this seems like a decent deal.thanks all....JT
post #693 of 701
Ya made a good choice. Let us know the results once you get it installed
post #694 of 701
Well I just put up my AntennaCraft-HBU55 outdoors
Seems that I only get 2 stations at this time (Signal is 47 - 50}
22.1 CBS WYOU and 28.1 NBC WBRE(it seems that I am in a YELLOW area for those 2 stations from TV Fool}
where as 16.1 ABC and 56.1 WOLF FOX That are in RED from TV Fool that I cannot get.
Maybe a AMP will help?
If I remember when I bought my Antenna Direct 91XG 4 - 6 years ago I was able to get the ABC but not FOX at that time
and I had read many stations have changed or relocate their ID numbers?
I also remember I was also able to get a Poconos weather channel.(Is that still avalable?.}..
UPDATED
I have gone too Antennaweb.org and put my Address in and NO stations showed up but if I put my zip code in then these stations shows that it can be picked up
Channel 22.1 and 28.1
(I only want the Wilksberrie stations}
Will it be that hard to get ABC and maybe Fox?
antennaweb.org/Stations.aspx?Address=&City=Brodheadsville&State=PA&ZIP=18322&Housing=M&Accuracy=4&Height=9&Obstructed=False&StationList=&Lat=40.9229722&Lon=-75.4053367
Edited by Johnnytuinals - 2/8/14 at 11:41am
post #695 of 701
Seems that the 2 stations that I pick up are VHF 22.1 and 28.1
All the other stations in that area are UHF (I thought UHF would be more easy to pick up?..
Would the AntennaCraft 30dB High Gain TV/FM Mast-Mounted Amplifier 10G212 for $35 would help?
Or maybe a CM or Winegard would be better amps?.Thanks allll...JT
post #696 of 701
A stupid-high gain pre-amp isn't needed unless you have extraordinary cabling or distribution losses. A medium gain, lowest noise amp will be your best bet.
The Antennas Direct PA18 would be my first choice as the lowest noise one, followed by the CM7778 or the WG LNA200
post #697 of 701
in most areas yes. But mountainous areas not so much. VHF signals "bend" over rugged terrain more easily than UHF signals.
post #698 of 701
I used to be able to get 41.1 PBS about 6 years ago with the 91xg
But now nothing..I will look into the Antennas Direct PA18 .Thanks JT
post #699 of 701
UPDATED
Today I installed my AntennaCraft-HBU55 and Antenna Direct PA18 Uhf/Vhf Pre Amp kit
With just the AntennaCraft-HBU55 my reading are
22.1 Signal 38
28.1 Signal 39
Picture is kinda breaking up here and there
Then installed the Antenna Direct PA18
22.1 Signal 72
28.1 Signal 82
41.1 Signal 22
50.1 Signal 16
22.1 and 28.1 came in great
As for 41.1 and 50.1 they don't come in but the stations pop up when I do scan for stations on my tv.
Any of you think this will be the best I will be able too do?
Seems in Brodheadsville 18322 area is kinda low in my area and not high in the mountains like other areas...................JT
post #700 of 701
for 41.1 and 50.1
There aren't any stations in your area with those displayed channel numbers. Check your data.
What direction did you aim the antenna?
You should also include your exact location TVFool plot. A generic zip code is usually close to useless.
post #701 of 701
Thanks for your time
41.1 is PBS
50.1 In ABC
Only area I can get is Scranton Wilks beirie area
They keep poping up whenever I recan
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d5b94bc575ec243
