Seeking a 4X2 (four input - two output) switcher that is for HDMI connectors. The switcher must also have TOSLINK optical output.
I have an older receiver that does not have HDMI connectors hence the need to use TOSLINK optical.
My four inputs will be:
-PS3
-media streamer
-Sony DVR
-HDTV Tuner
outputs will be:
-an LCD TV
-a projector.
I do not need to mirror the outputs - just want to be able to select either/or from LCD TV or the projector.
If the switcher has more inputs, example: 6X2, I'm good with that too
In reading various posts, a lot of folks are using one from Monoprice - unfortunately, I do not have COAX optical outputs on some devices hence the requirement for a TOSLINK optical based switcher.
any reasonable suggestions ?
-PS3
-media streamer
-Sony DVR
-HDTV Tuner
outputs will be:
-an LCD TV
-a projector.
