Originally Posted by DonH50
I have noticed a trend toward higher SQ in remastered material targeting higher-quality medium. My opinion is also that the magic's in the mastering, not the bits... I have also heard plenty of re-issues of old vinyl favorites that sound like... well, "poor", despite the fact that CD's have higher resolution and generally better performance than LPs. (Oops, that'll start a debate!)
amen... imo/ime, if the mix/master is good, it doesn't really matter a hill of beans what the bit/sample rates are... i buy and spin sacd's, for three reasons:
- the mix/master tends to be better...
- multi-channel...
- because i can...
but if a hybrid sacd has as "good" of a mix on the cd layer as the sacd layer, and i ripped that cd layer to a 256vbr aac file and play it back from my mac mini, you have to listen VERY hard and know what to listen for in order for any differences to be heard... you can compress the crap outta stuff with a "modern" codec and get very good results... and if you are a bit more generous than 256vbr, you can get outstanding results...
whereas if the mix/master is crap, all the bits in the world won't make a difference... it's gonna sound horrid, regardless... and the sad part is, as you move up the sq ladder (better speakers, improved room, better resolution room eq), it only sounds MORE horrid...
there's a lot of preconceived notions about bit/sample rate, some from experience (i.e. people who listened to a mp3 10 years ago on a crap pair of buds, for example), and some from assumptions (i.e. "more" data HAS to result in "better" sound)...
ymmv, imo, ime, etc.
Toole's book is also good, but Everest is my "go-to" book, especially for a quick answer and an easy read for the competent layman.
gee, what a surprise, we agree again...
you can't spend a better 25 bucks in audio than the everest book... the bang for the buck is off the charts... and for someone like me, who doesn't have any advanced degrees (unless you consider a hs diploma an advanced degree
), it's very accessible... i don't have to reference another book to understand what he's trying to tell me...Quote:
For the deep stuff, I go to my grad acoustics texts, but I've reached the age when multi-dimensional nonlinear wave equations give me a headache...
the hard stuff is what you guys are around for...
the stuff i don't understand, i "accept to be true" when advice is given from people i trust, and simply apply the advice... eventually, by applying that advice, i come to at least a rudimentary understanding of what i'm doing...
. What do you mean by "and not symmetrical about the Centerline"?
