Originally Posted by
Flash676
I've had the 55" HX929 since August and it doubles as my PC monitor. As a result, the TV is used for all of my gaming, be it PC or console.
erial, but I do find myself struggling with some of its limitations:
1.) Blooming is very noticeable with abrupt light/dark transitions.
I don't notice this at all. There is some blooming overall under some circumstances, which is the nature of full array sets, but there isn't any increase in blooming with scene transitions for me.
Flash676
2.) Substantial lag for gaming in most scene select options.
Game mode is definitely needed. Or at least the settings need to be optimized for SPEED.
Flash676
3.) Reduced local dimming effectiveness in gaming scene select option.
This is pretty marginal and not noticeable in-game at all for me, only when a full black screen is present. I play LOADS of very dark games and nothing has come up as an issue at all.
Flash676
4.) Limited options for smoothing motion. I'd like to be able to strobe the backlight without using frame interpolation but the two are tied together..
I am not sure if you are talking games here or not. Doesn't really matter, the motion on this LCD blows away anything I've used previously. I'll give a nod to plasma for movies in regards to motion, but plasmas definitely have other issues. As for games, I am playing 1080p/60Hz and 60fps (v-sync enabled) and I've NEVER played on a better TV for games.
Flash676
5.) The TV is overwhelmingly bright when used as a monitor in the dark, even with the backlight reduced to minimum.
Yeah, I'm not sure what your settings are, but I am using backlight of 4, picture 85/brightness 48 and it isn't too bright for me. I am using the set as my primary monitor as well in a pitch black room. My walls and ceiling are painted black and the carpet is black/grey and there are no windows...doesn't get darker than in here. I didn't even adjust my video card brightness settings, but that would be an option too I suppose if you find it too bright. I find brightness settings set too low really affect HDR lighting and other lighting effects in game.
Flash676
Obviously, all TVs have their own set of compromises you'll need to consider. Best of luck in making a decision if you haven't already.
Yeah, we definitely have different experiences...I've never been a happier gamer, period. Currently playing Arkham City on PC with DX11, every setting on the NVIDIA controls maxed, every setting in game maxed and it looks AMAZING. Simply stunning looking and performance from the TV is exceptional. It is a pretty dark game and there is no blooming or any other issues to speak of.
Sorry, crappy camera...weird field effect are from the camera, not in-game.
