Originally Posted by spoolthis
just like others have mentioned. id rather play with the settings or apps before i start a movie, therefore asking if there was a way to disable auto-start from the home screen. but its fine, i can live with it, to bad there wouldn't be such an option for something so easy to implement.
thanks for the responses.
If you are in the apps and you insert a disc, the player will not auto-start. That was easy.
