AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official Panasonic DMP-BDT110/210/310 Owners Thread
Official Panasonic DMP-BDT110/210/310 Owners Thread - Page 207
post #6181 of 8308
Originally Posted by RedHot5 View Post
Hi all, I just bought and setup my new Panasonic DMP-BDT210. I bought this player because I read reviews that stated how this was the fasted loading Blu-ray player on the market and since that was something that always turned me off with Blu-ray I figured I would pick one up and see if it lives up the review hype.
I noticed something strange when we were watching our first disk and hit the internet to see if I could find a solution. I found this thread on the AVS forums and started reading about everyone else's experience with these players to see if I could find an answer. Unfortunately I don't have the time to read all 206 pages of this thread and when I searched for threads talking about the issue I didn't get any results.
Here's what happened. We sat down to watch the B.T.T.F. 25th Anniversary disks and started with some of the special features. We paused the disk to take care of something and when we came back the Play button didn't start the playback right away so I stopped the disk and started it up again.
We navigated back into the same special feature we had been watching and then fast forwarded to the spot we left off at. When I pressed Play to stop the fast forward and start playback again the video started playing but there was no audio.
I stopped the disk again and restarted it. Again the intro played with full sound and we navigated to the special feature. We started the special feature and it had full sound again. I fast forwarded one level and pressed Play. While it was fast forwarding the sound was playing over the sped up video and when I pressed Play it went back to normal. I then fast forwarded two levels and pressed Play. While it was fast forwarding there was no sound playing over the sped up video and when I pressed Play the sound did not come back.
So to sum it up, it seems like fast forwarding higher than one level of fast forward speed kills the audio.
This has never happened with any of the other AV equipment (Xbox360, RCA DVD player, etc) we have hooked up so I don't think it's my AV receiver or setup that is causing this to happen.
Any thoughts?
Additionally, I am used to DVD players that restart the video where you left off if you stop the video, turn off the player, come back later and start playing the video again. This doesn't seem to be how the Panasonic player behaves by default. Am I just not up to date on how current players behave (admittedly it has been quite a few years since I bought any new players) or is there something different about this player?
I appreciate any and all feedback that anyone can offer.
Thanks In Advance
RH5
I think it is your receiver. What happens is that when FFW, BD audio stream get cut off in higher speed. When you hit play, it restarts the audio stream. Some AVR may not like this kind of change. None of your other equipments you listed outputs hi-def audio like a BD player would. Did you also update your player's firmware to the latest. Also try change the audio setting to player decoding (use PCM instead of bitstream) if you have a HDMI receiver to see if it solves your problem.
To be clear, Panny player is rated the fastest loading a BD disc. Not the fastest from power on to ready to load disc. It's kind of misleading rating. I owned a Sony S570 player briefly and it is much faster than my Panny from power on to ready to load disc.
post #6182 of 8308
forgive my simple question, but question is confusing for me.
what color setting should i use for blu rays, ycbcr or rgb? i have a sharp 60" 632 if that matters.
post #6183 of 8308
Doesn't matter much either way. All movies, BluRay or DVD, are natively encoded as YCbCr on disc. HDMI interface typically defaults to YCbCr for reduced bandwidth requirement. However, at the end, your display panels are all in rgb pixels. So, if you chose rgb, the conversion from YCbCr to RGB happens in the player. Otherwise, your TV will have to convert them to RGB when display on the panel.
post #6184 of 8308
Originally Posted by Brandenborg View Post
msn, I had a problem like that with my 110: Everything worked (BD, NetFlix, Amazon, Vudu) except audio in Pandora, YouTube and Viera Cast navigation sounds (which I disable anyway).
I wrote about it in previous posts, starting with #1707 " www. avsforum. com/avs-vb/showthread.php?p=20469970#post20469970"
After spending much time with Panasonic Support, they wanted the player in for service. I replaced it through Amazon, but the new unit has the same problem. I've found solutions, though, and some odd workarounds:
1) No audio settings will affect this, don't waste your time. I also tried a new expensive HDMI cable (specifically supporting HDMI 1.4a, ARC etc) and multiple resets of both TV and player, all with no effect. It is a flaw in the Panasonic negotiating HDMI with my Mitsubishi TV (HDMI 1.3).
2) Disabling Deep Color solves the problem (Under TV/Device Connection - HDMI Connection) -- but is not acceptable to me as my TV specifically supports Deep Color. I also have a Vizio 3D Blu-Ray player which plays 36-bit Deep Color perfectly on the same TV (including Pandora and YouTube).
3) Changing HDMI Color Mode (also under TV/Device Connection - HDMI Connection) from the default YCbCr 4:4:4 to YCbCr 4:2:2 ALSO solved the audio problem. This is more acceptable to me as most H264 material only contains YCbCr 4:2:0 data anyway. But it's still not ideal, as I am loosing out on the Panny's advanced Chroma Processor which might produce smoother gradations than my TV's older processor. At 4:2:2 these details cannot be delivered with full accuracy to my TV.
4) Here is an odd trick: Even without changing these settings, if I enter YouTube on the Panny and play a video (which will have no audio) then AFTER leaving YouTube again -- audio suddenly works in Pandora (as well as those navigation sounds). YouTube video still won't have audio, though -- it is disabled just before videos start playing.
Clearly the Panny firmware and/or Viera Cast apps perform a test of HDMI capabilities at various points (entering Viera Cast, before starting a YouTube video, and a few other places) and incorrectly concludes that the TV does not accept the bandwidth required for both YCbCr 4:4:4, Deep Color and audio -- and then disables audio.
As both BD, NetFlix, Amazon and Vudu play perfectly with those "full bandwidth" settings -- AND so does Pandora and everything else when the player is "tricked" -- I conclude this is a flaw in Panasonic's HDMI drivers.
I tried convincing Panasonic Support of this when I spoke to them -- I can point their developers to half a dozen events where this flawed test is invoked and audio incorrectly disabled/enabled. But they didn't seem to be interested when they heard I was using a Mitsubishi TV.
It's still a great player, and I can live with these peculiarities now that I know how to work around them.
I'd love to hear if your problem is the same and if you can "trick" your player with YouTube the same as mine.
Brandenborg:
I just purchased the BDT210 and connected it to my Mitsu WD-C657 DLP. It's connected directly to the TV using HDMI, with no other devices, receivers, etc.
I have the same issues with Viera Connect, meaning no audio from ANY of the apps (Netflix, YouTube, etc).
I just want to say that I followed your advice with regards to Deep Color and HDMI Color Mode, plus I turned off '24P', and VOILA, I have audio in all of the apps!!!
I went back and set Deep Color back to 'Auto', but left HDMI Color Mode at 4:2:2, and everything still works fine; if I change Color Mode to 4:4:4, no audio.
So, the culprit (at least in my case) was only Color Mode.
I just want to give a big 'thumbs up' for your solution. I never would have figured that out. I was ready to pack it up and return it, until I saw your post. Outstanding!!!
post #6185 of 8308
Originally Posted by JSnyder2914 View Post
Brandenborg:
JSnyder: Wow, good job on finding that old post. (That's how you do it, guys: Spent a little time searching and reading).
And thanks a lot for the feedback :-)
I am pretty sure you can enable EITHER Color Mode 4:4:4 OR Deep Color - just not both at the same time, that's what kills HDMI audio. At least that's how it works on my Mits. You can keep 24p on if you want, it shouldn't affect this. (If your TV does 96/120/240Hz, otherwise 24p won't matter).
I am still convinced that this is simply one more symptom of the Panny's flawed HDMI implementation, particularly at max bandwidth. Half the posts in this thread are about HDMI audio connectivity...
I've since connected the player directly to my analog stereo and skip HDMI audio altogether. That way I can keep both 4:4:4 AND Deep Color. That said, 4:2:2 is almost no difference, and definitely better than disabling Deep Color. Some people even prefer 4:2:2 for "purity" to reduce the amount of chroma processing in the player. That's another discussion entirely ;-)
post #6186 of 8308
My 210 does not have these issues at all with my TVs or my AVRs.
Seems like an issue with your Mitsus.
post #6187 of 8308
That's good, congrats. Indeed, many people have no problems with their Panny - fortunately.
But it doesn't play nice with Mits HDMI, Panasonic tech support admits as much. No problems with other devices on Mits TVs.
If you've followed this thread for some time, surely you must have noticed how many HDMI issues people are having, most of them audio/AVR related. Some are due to AVR settings. But the HDMI drivers on these players are simply not a solid design.
I still like the player, it's great value and it gets a lot of use in our home. But between the NF issues, the HDMI handshake problems and the ridiculous (misrepresented) file support, I believe most users could legitimately insist on a return or warranty swap if they chose (not that I'm going to). I think Panasonic would be crushed if somebody decided on a class action suit.
post #6188 of 8308
I'm with Rathbone. I haven't had any issues at all with mine other than the Touch Sensor stopped working after a couple of months (but that's not a big deal). Plays beautifully with my Yamaha AVR and LG LCD. Of course I use it just for DVD/BDs and streaming and not any of the other formats that a lot of folks seem to have issues with. Guess I'm just not with the times in that respect and yes, it gets constant use.
post #6189 of 8308
Let me try again: I am not attempting to convince anybody that their players are bad if they work well for them. For those who've never had hdmi problems, never seen the Netflix flashes, never had router connection issues and never experienced file compatibility problems - that's great.
For me these issues have been relatively minor - things I could work around - and outweighed by some great features and a low price. I use the player a lot - even including it's infamous file playback (which some would call nonexistent).
But objectively speaking, I have to say that it is one of the the buggier consumer electronics devices I've owned. That's all.
Update: For completeness I should add that I never had problems playing BD either. That part of the player works very well.
post #6190 of 8308
Hey everyone, I just picked up a bdt-210 and am running it through a htss 380 sony 3d home theater system... Now I was just wondering to set the audio settings too in the menu to make sure i get the lossless audio...
also wondering if it's possible too make this player region free???
post #6191 of 8308
double post
post #6192 of 8308
Use HDMI and set Secondary Audio to Off.
post #6193 of 8308
...also wondering if it's possible too make this player region free???
DVD region free works fine with same panny one-for-all remote hack that has been around for years (discussed in detail earlier in this thread). BD region free only available by somewhat questionable and expensive custom firmware. Much cheaper region free player can be had in an Insignia which is about $40 used.
post #6194 of 8308
My apologies if I sounded argumentative. That wasn't my intention. I just wanted to point out for those, like me, who just use it for movies and streaming, that it's a very nice unit for the price and relatively trouble-free.
post #6195 of 8308
No, no, you're fine. In fact I always enjoy when people post their positive experiences since this thread can give the impression that nothing works on these Pannys - which absolutely is not correct. They ARE great disc and streaming players, and they ARE great value.
I think I've dug myself into a hole here and I'd better stop digging
post #6196 of 8308
I just bought a pany bdt210 and was setting it up, can anybody suggest any settings/tweaks for it? Thanks in advance!
post #6197 of 8308
skip this post, nothing to see here, folks. And skip the next two while you're at it. momentary lapse of reason (or so I hope).
post #6198 of 8308
I don't see any change. I think you forgot this is 2012, so only one more month left on the rebate as always.
post #6199 of 8308
Doh! Yep - totally blanked on that. Fortunately, I have been writing "2012" on checks 'n stuff.
post #6200 of 8308
You can borrow my shovel. It's seen plenty of use
post #6201 of 8308
I just got a 210 and am having problems with it seeing my video collection on my PC. It can't seem to see most of my videos, won't fire up Windows Media Player, and I can;t seem to figure out where it is pulling the videos it will show me from.
Any thoughts?
post #6202 of 8308
You cannot say for sure which piece of hardware is responsible for the issue. Example with my equipment.
My Oppo BDP-93 has heavy HDMI handshaking issues (up to 30 Sec. black screen and static noise until I see a picture, then have to go back to the beginning of the movie) with my Yamaha AVR RX-V2067 but worked fine with the Denon 2311 AVR I had before. On the other side all other BD players/HTPC/cable box work fine with the Yamaha. Now Yamaha blames Oppo and Oppo blames Yamaha.
post #6203 of 8308
True, it takes two to dance, and also two to have an hdmi handshake problem ;-)
post #6204 of 8308
Hi all:
I have a couple of portable 2.5" USB 2.0 drives. I see on page 7 of my BDT210 manual that FAT12 FAT16 and FAT32 are supported - so I think that that explains why my BDT210 can not read any of my NTFS drives .... BUt I have a 40 GB Samsung FAT32 drive that it won't read either - it just says "USB Device is Incompatible".
Is there a thread somewhere that might help me find my problem?
post #6205 of 8308
Originally Posted by IanS View Post
Hi all:
Is it powered? It must be.
S~
post #6206 of 8308
S~
It's a 2.5" drive that I've never used an external PS with. It always just works on any PC or laptop. Does the BDT210 demand external power for all USB drives?
post #6207 of 8308
I just found one problem with the 210 concerning VUDU. I went to my account on VUDU using my PC and found many 3D movies using their search function. I put a few in my wishlist, but when I logged in on my 210 they weren't there. I called VUDU and they said the 210 does not support 3D steaming, suggesting I contact Panasonic to see if they could fix it. I mean sheesh, it's a 3D Blu-ray player. Maybe they'll fix it in a firmware update.
post #6208 of 8308
Yes. That's why I asked
S~
post #6209 of 8308
They haven't fixed it yet and it's been about a year since it came out.
S~
post #6210 of 8308
That seems a bit strange. There has to be power on the USB connection to use USB flash drives--the flash drive that I've used with it has a little activity light that works fine. Are there two standard power levels and USB-powered HDDs require the higher one?
