"Are you saying that you've hooked the soundbar to the television and when you tune a channel with its internal tuner which has 5.1 sound you only get 2.1 channel sound from the television?"
Yes, that's pretty much it. It's been a while since I wired all the system up, so memory may be a bit fuzzy on some of the details.
I got the Panasonic (TC-P42G25) when my old Mitsubishi CRT large-screen finally died.
At that point I was building a "Home Theater PC", which was completed and installed with all functions working, including remote control of the cable box. I'm sad to say that the "Home Theater PC" experience has been "less than satisfactory", and it has apparently had a hardware failure and won't boot. So I've decided to "can" the HTPC and just go with commercial stuff.
The big item is being able to play Blu-ray and access all it's "bells and whistles" (except 3D....my interest in 3D is miniscule).
So, the "root question" is "will a Panasonic BMP-BDT210 player send 5.1 sound to the JVC-THBA3" by whatever route, whether that be optical HDMI, (or telegraph......)
I can live with not having 5.1 from the TV.
"The manual for your soundbarseems to say that it doesn't have HDMI connections. If this is true, and you've got some other device hooked into the television via HDMI (like a cable or satellite STB, game console or streaming box) and the television hooked into the soundbar via optical S/PDIF, what will probably happen is that the HDMI device will obtain a description of your television's capabilities (called the Enhanced Extended Display Identification Data, or E-EDID). this way; sadly, it was a while before that "don't send sound through HDMI" setting was added to cable box firmware)"
. Today's AV electronics landscape is somewhat different than the future envisioned 14 years back when S/PDIF was standardized.
