AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official Panasonic DMP-BDT110/210/310 Owners Thread
Official Panasonic DMP-BDT110/210/310 Owners Thread - Page 239
post #7141 of 8308
Originally Posted by RaptorX View Post
BTW my touch-free sensor stopped working AGAIN. Unplugging the player for several minutes fixed it this time too.
How many others have had the "sensor" stop working? Mine stopped for a week and then worked again for a day or so and now not again. I haven't unplugged it yet but didn't know if this is widespread or what? I'm still under the 30 days after getting it from Amazon and it's not a big PitA right now.
But on a happier note my Avatar 3D came the other day. Took about 3 weeks.
post #7142 of 8308
Anybody have thier 310 hooked to a tx-sr805 onkyo reciever? I get picture but no audio, looks like handshake issues (HDMI flashes on 805). All settings in player are correct for this setup, any advice? Thanks!
post #7143 of 8308
It should be noted that the touch free sensor is not a feature on any 2012 model. Perhaps they decided that there was no way to make it reliable.
post #7144 of 8308
Are you sure about that? If it setup correctly, you should get audio then
There are quite a few ppl have this same issue (some on Onkyo receivers). Do a search. There are advices given for correct setup as well.
post #7145 of 8308
Mine stopped working for a few months. I moved houses, and either simply unplugging it or the movement from the move got it working again. I have to say it's a real bother when you're trying to working behind the player to connect your home theater and the drive keeps opening.
post #7146 of 8308
[quote=DR.DTS;21710651]How many others have had the "sensor" stop working? /QUOTE]
Mine stopped working after about 3 months or so but it's not that big of a deal to me. Every time I dusted it would open which is a hassle so after it stopped working, I just made sure the feature was disabled in case it came back to life. For me, it wasn't that useful of a feature anyway. When I switch devices with my Harmony, the door opens automatically before I can even get up and walk over to the unit.
post #7147 of 8308
I double checked the settings. I used a tip from another forum, but it is a pain. I have to put the tv on another input then start the movie. The audio "syncs" up with the player then i put the tv back to the correct input to see video. It cures the issue, but is a real pain...
post #7148 of 8308
Sounds like you may need to delay switching the function mode on the AVR, such as going from CBL/SAT to DVD, until the BD player has fully powered up, which could be 8-10 seconds or so.
post #7149 of 8308
Sounds like common problem with Onkyo 805. See post #6450 (http://www.avsforum.com/avs-vb/showt...st21556907)and read my suggested settings following that.
post #7150 of 8308
Make's me glad that I bought the much less expensive TX-NR509 (not that I could have afforded the SR805 ). It's worked perfectly with all 7 sources I have connected to it.
post #7151 of 8308
IIRC, you didn't have 310, do you? It's a different story for 310. You have to make sure both HDMI ports are handshaked properly in order to see both 3D video and HD audio. It's quite difficult to get one HDMI chain to sync up. I can only imagine sync two HDMI chains will be such a nightmare.
post #7152 of 8308
I suspect quite a few 310 owners choose this player for its checkerboard format and dual hdmi like I did. I have a Mitsubishi DLP and 3da-1 adapter but had hoped to use the adapter only when viewing cable. I have found that 2d-3d conversion doesn't work when output is set to checkerboard and there is no VUDU 3d! Is there any online 3d except VUDU? Would it work in checkerboard?
post #7153 of 8308
What he meant is that you can set your player's output resolution manually. But that's probably not what you wanted because if you set it to 480p (for DVDs), your Blu Rays will be down scaled to 480p as well. There is no way to set output resolution to automatically match the source. So, forget about the external scaler idea. It will not work with this player or any other consumer grade players out there.
Meh...I guess I'll continue using my PS3 for standard def playback. That does output 480p. I suppose I was hoping for too much from a $100 Blu Ray player...
post #7154 of 8308
I have an 805(connected forthe past 4 years) and a panny 310 still in the box. I'm trying to complete a media room before I put those 2 together, I'm thinking I might have the handshake problem as well. I will be using a Mits, DLP 73" TV in this mix and I also have the 3D starter kit. I was told by Mits that with a firmware, (sent by them to me), I would not need to use the 3D box in the kit but only use the emitter for the glasses to work. I was also told on here that if I do 3D in checkerboard throught the DLP the 805 will pass that 3D signal right through to the TV. If that is the case shouldn't we be telling folks on here that there is no need for a Panny 310 with the extra HDMI for this configuration and I suspec using it with other older DLP's from Mits and Samsung? In your case if you use just the single HDMI from 310 to 805 then output it all to your TV would that work, i.e., sound + picture?
post #7155 of 8308
Thank you for directing me to that post. I can get it to work, but if I pause the movie I have to do everything all over again. I will continue to try different methods because I don't want to return the player or replace my 805...
post #7156 of 8308
Hello everyone, I am new to this forum, and have scanned trhough hundreds of pages, and if I missed the answer to my question, I apologize in advance.
I have purchased a 210, using the 1.8 firmware, am using a Cisco E3200 dual band router, using the wifi function in the player.
No matter what type of wireless connection I use, 2,4ghz or 5ghz, with any type of security encryption, the wireless disconnects nearly daily. I need to go back into the player network setup, and reestablish the connection. the ip configurations are correct (I am an IT professional). I've tried both static and DHCP, reset the router, etc.
It's not convenient at the moment to run a cat 5 drop from the router to the player at this time.
Has anyone experenced this issue, and if so, is there a fix?
Thanks for your help! :-)
Rick
InsideKSC.com
post #7157 of 8308
I have the same router and a 210. The only problem I ever have is if I try to go online too quickly after I turn on the 210.
post #7158 of 8308
Checkerboard may pass but I think you will lose the 2d-3d conversion. l have a 73835 that requires the adapter btw.
post #7159 of 8308
So has any passed 3D from the 210/310 to the Mit without any adapter? I have the 210 and 65736 Mit but no 3D movie and no 3D glasses. So no way to test.
post #7160 of 8308
Yes. I have the 310 and have tried it with checkerboard and it works without the adapter but the 2D-3D conversion doesn't. When I connected the adapter the output automatically switched to Full 3D and the up-conversion worked . I was planning not to use the adapter so not thrilled.
post #7161 of 8308
Thanks for responding. I read somewhere here that the 2D - 3D conversion is a hit and miss situation. Some movies are nicely converted and others are not.
post #7162 of 8308
Quick question for 210 owners - is this player able to display Time Remaining on either the front panel display or the on-screen status display?
Thanks in advance
post #7163 of 8308
I have the 65735, been watching 3D with the 210 for several months now, no adapter required. Just had to set the output to checkerboard. I have to fiddle with my Logitech Harmony settings, because if the 210 initializes before the TV does from a cold start up, the player won't recognized the TV as 3D.
Oh, and you also have to turn 3D on in the TV settings. I didn't do that the first time, so I got real nervous when I first fired up a 3D movie and it said I didn't have a 3D compatible display.
post #7164 of 8308
Thanks in advance
only shows total time and time elapsed. you need to know how to subtract with the panny.
post #7165 of 8308
Just picked up a 210 (actually a 215 from Costco), so far I find there is a lot to like about this unit.
After searching this thread I was able to configure it to play MKV files from my Network and so far I have only had one file not play out of thirty or so....
Issue I am having is that it only lists about Quarter of my movie listings in the sub menu list, is there a limit to the number of files shown???
I have each of my movies in it's own folder under the network share, Any help would be appreciated on understanding how it handles network files.
post #7166 of 8308
Your TV and mine are practically identical. What kind of 3D glasses are you using for your setup?
post #7167 of 8308
Problem solved!!
I put everything back to my initial settings:
310: HDMI main to tv, HDMI sub to 805 (audio only).
805: HDMI audio out off
I turned off the hdmi monitor function on the 805 and everything works perfectly! No hiccups, I can turn everything on in any order and it works without issue.
Thank you everyone for your help, I appreciate it!
post #7168 of 8308
Rick
InsideKSC.com
if none of your other devices are disconnecting, it could be the player.. however, is the location of the player within a good signal strenght of the router?? see if you can put the player close to the router for a few days and check it if disconnects (use a monitor with dvi and use a hdmi to dvi converter)
just my 02 cent
post #7169 of 8308
Is the 210 able to accept a gigabit connection or only 100?
post #7170 of 8308
By standard, 1000BaseT routers are required to be backwards compatible with 100BaseT. (The BDTx10 specs say 10/100BaseT, BTW).
