Thanks John.
I thought it might be a defective Panny but the thing that rules that out I think is that if I connect the Panny via its HDMI MAIN directly to the TV then I get picture and sound. If I attach the Panny directly to the TV via is HDMI SUB I only get sound (which is correct). So I know the Panny is outputting exactly what it is supposed to.
I think it is just a case of the Kenwood not accepting the signal for some reason. I did note that when the Panny is connected to the Kenwood and I get no signal, when I press the display button on the Kenwood remote the Kenwood does not report "No signal" (like it does when there is nothing connected) but it reports "Unknown".
Anyway I have taken the plunge and bought a Pioneer VSX 826 K. I hope I get better results with that!
Darin.
Darin.
. Of course, you don't have any guarantee that the BDTx10 will play your files once you have them on something that it can read; you might want to put a few on a flash drive and try them from there.
