As promised, I did some disc load timing between my old DMP-BDT110 and my Sony BDP-S390 (a non-3D version of the S590 with a smaller enclosure, no external display and a single USB port but otherwise identical features). Starting a chapter from the main menu took a trivial amount of time for either, with the BDT110 being slightly faster, but it was like 3 seconds versus 4; in the noise. Disc startup times were a different matter. As I remembered, the Panasonic was always faster; depending on the disc it was a little faster or a lot. Timing from closing the drawer to the start of the front titles and credits (Harry Potter and Blade Runner) or to the menu being up and usable (T2 and Avatar):
The Avatar disc required a persistent store to start without pausing to ask for one, so I used 4GB flash drive, freshly formatted for each. I timed the start-up of these discs 3 or 4 times each on either device. As you can see, the difference wasn't huge (8-11 seconds), except for Avatar.
I suppose that it's possible that the S590 is hugely faster but I doubt it.
- Terminator 2: S390 50 secs; BDT110 39 secs
- Harry Potter and the Order of the Pheonix: S390 68 secs; BDT110 60 secs
- Avatar (2D): S390 98 secs; BDT110 60 secs
- Blade Runner: The Final Cut: S390 80 secs; BDT110 69 secs
). It burns about twenty times as much power in operation as one of these BD players (literally 100 times as much as my Roku 2) and its fan is loud enough to hear in the space where I use it (it's a 60GB launch model; if you have a Slim, you can halve the power usage and its fan might not be audible during BD playback, but still).
