I took these pictures with my iphone so the quality isn't great. I'm also not quite finished (concealing wires, adjusting doors on media console, etc.) but it gives you an idea of the final product.
Equipment:
AVR - Denon 1909
L/R - Definitive Tech SM450's
Center - Definitive Tech PM2000
Surronds - Definitive Tech BP1.2x's
Sub - Epik Empire
My setup is pretty straight forward, but I guess a few comments are worth noting.
I just upgraded my media console. I went from a wall unit to this low profile console from Ikea (besta collection). I really like the look and cost ($290) of the Ikea console but it wasn't made with the home theater enthusiast in mind. My AVR didn't quite fit given the relatively shallow depth of the shelves, so I had to cut out a rectangle in the backboard so it could protrude out the back and therefore sit recessed in the shelf. Cutting the backboard was pretty difficult too. I didn't have the necessary woodworking tools so I used a combination of a circular saw (total overkill) and a drywall cutting tool. It was a pain to cut to say the least. The other drawback is ventilation or lack thereof. With the doors closed my cable box overheated. I may either take the glass doors off or leave the door ajar when watching TV. Overall though I'm happy with the media console because it was cheap and stylish.
I also mounted the TV myself. It's probably common knowledge on these forums that monoprice makes this task cheap and easy with their inexpensive mounting brackets and recessed wall outlet. Every TV is different so I won't post a link to the bracket I used, but below is a link to the recessed power outlet that anyone can install. I highly recommend this unit. An electrician would have charged close to $300 plus hardware to mount my TV. I did it for less than $70
Equipment:
AVR - Denon 1909
Sub - Epik Empire
