I've done some read-up on this, and I think I'm just about ready to start planning out a purchase for a projector. Is now the best time? What's the best place to buy? Do deals come frequent?
Anyhow:
I'm using a 42" calibrated Toshiba Regza LCD at the moment, and I absolutely love it even though I'll have no need for it and have to sell it after this :*(. But it's come time to really increase the theatrical fidelity, and I'm ready.
Here are my requirements:
I may be moving a time or two during it's lifetime. I'll need something that's adjustable and dynamic, so I've settled on an LCD projector.
Do LCD projectors produce the "bright darks" like almost all LCD screens do (the matted part of the image) or are they typically better?
I want to throw out 120" (if I do happen to have 12-14 feet or so of distance). If I so happen to move into a room that's only 10 feet, then it will be obviously less. 120" is my goal, though. If it has to be 80" due to future room constraints, than so be it (for the time being).
I want 1080p.
This will be placed in a converted bedroom and not a living room. That means, I can control the lighting much better, and it will be away from the common noises of living rooms that seem to always be next to kitchens. If there's going to be a window in the bedroom, it's going to receive black drapes.
Until I get fully settled into a house (my work is temporary at the moment, but will probably change into a salary soon), then I'm going to avoid painting the wall a matt dark color. The painting will probably be white at first (this is an on-going ordeal), and I'll see what I can do with this after-the-fact giving my conditions. Same goes for soundproofing material.
I'm thinking about building my own screen, but if there's something that would work great for the cost and much less effort, I'd like to get recommendations on this as well.
I'm not a person that thinks you have to pay out of your ass to get good performance and a quality image. All you need is an informed decision on a great product.
Budget is $1200. $1400 with screen. Maybe more if need be.
I already have a receiver with nice Polk speakers and a custom 18 x 18 x 18 Sub that would scream in a converted bedroom.
This won't be used for TV (I never watch that anymore). It's going to be used mainly for movies, and the occasional gaming.
I'm only a projector away...
Anyhow:
I want 1080p.
