If you are considering this set buy it you will not be disappointed. I got mine last night, hooked it up real quick to run it through some test and was fairly impressed. Watched Tangled in 3D and it was amazing, everyone in the room was absolutely floored with the picture and the 3D. Picture was bright and crisp absolutely no deterioration of the picture quality because of the passive technology. The only thing i noticed, and I think another reviewer mentioned this as well, is that at the very bottom of the screen the bottom 2 rows of pixels were always green and pink. Not a big deal when watching bright scenes but when watching dark scenes it is very noticeable. This only happened while watching bluray and not while watching tv or gaming. I'm thinking it has to do with the input source and is not the tv, so i will have to play with it and see what i can come up with.
As far as gaming, I had my son play a couple of PlayStation 3 games both converted to 3D and just regular 2D. His verdict is that there is a minor delay but nothing that is a deal breaker. I'm going to try KK's settings this evening and see if that will reduce the delay.
Before i bought this set i was concerned when someone mentioned that this set is not good when watching in a very dark room. Not true at all. This set looked ridiculously good in a dark room. Minor and i mean minor clouding when the screen is all the way dark, however i was the only one who noticed it and i had to look pretty hard to see it.
The only other 'complaint' i have is with the glasses. I have a large window directly behind me when watching and i was getting a glare on the inside of the glasses which was kind of distracting. Again not the sets fault i just have to make some adjustments with my room.
Overall this set is exactly what i was looking for. If you can get an excellent deal on it i say jump right in and make the purchase, it will not let you down. I will play around with it some more and post updates later on.
. They had it on display and i was very impressed with the 3D with the real 3D glasses. Way better IMO than the standard flicker expensive glasses. Much more comfortable to wear & it does not darken the picture as much. The set seemed to have great viewing angles. And if you stand 6 feet back like the demo recommended, those "banding" pixelated type lines were not visible as others noted while 3D was active. I was very impressed by the cinema 3D. The Under The Sea demo was awesome the fish actually came out of the screen a bit rather than just adding depth.
. So i asked the guy if they would price match and he said yea i should be able too. I also noticed last week in their ad if you got the TV you got a free LG 3D wifi blu ray player. He also said he would include that in the price. Which i had to go pick up at another store. No big deal. But the wifi blu ray player makes up for the sharp i returned having it built in the TV. & me not having to run another wire through the wall lol.
lol.
