AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official LG 47LW5600/55LW5600 "Passive 3D" Owners Thread
Official LG 47LW5600/55LW5600 "Passive 3D" Owners Thread - Page 202
post #6031 of 8099
Originally Posted by timtlm View Post
Success! The $5 RCA RCR3273 does work. To program, just hold the TV button and enter 11265, then release the TV button. Then the guide button will bring up the service menu prompting for the 0413 password.
http://www.amazon.com/Device-Univers...dp/B000N2MW5G/
thanks.. just ordered.. should be here on friday..
funny thing about amazon.. soon as they get a bunch of orders.. price creeps up.. i got in at $5 this morning.. now its $9
post #6032 of 8099
Originally Posted by bkgraham33 View Post
2 questions... I just bought this TV yesterday and am having my doubts about how great it is. My 2 current issues are this.
1)When I try to watch a 3D movie from the PC I can't as the only option I have when I click 3D on the remote is '2D-3D'.
2)When I play .avi files that otherwise look really good on any other monitor/TV I've used in the past (even my projector with a 134" image), they look really crappy on this TV. Everything else about the OS looks fine on this TV, just not videos. Resolution doesn't make a difference, the level of crappiness is consistent. Surely there's a setting somewhere???
Hey bkgraham - sorry to hear that you are having some hiccups with the set but once we get them straightened out you will definitely love it! From your posts I gather that A) You are not connected via hdmi to the set because B) you do not have a graphics card or your motherboard does not have an hdmi out (and therefore your chipset may not support 3D).
What PC are you using and what CPU do you have? How are you connected to the tv?
post #6033 of 8099
So got my set 2 nights ago and have to say am very impressed. Used the settings on page 8 from Kandionkhrome and they definitely make an improvement from the stock. Did try also the settings from mrjktcvs (page 81) but found them to be a bit washed out for me - but I may need to adjust to reflect the lighting situation in my living room. Still have not played a game yet to check out the lag and confirm the fixes that others have use work but all in all very happy with my purchase.
The only issue I have is playing 3D iso's from my HTPC via Total Media Theater (trial version) and my ATI 6850. They play fine and the 3D is working but the image is not taking up the entire screen. It's not letterboxing - the black bars are on all sides - not just top and bottom.
Also, has anyone gotten the 3D Zone app to work on their LW5600? I installed the app but when I try to access the app it goes through the motion and then I get a pop up that the service is not available (or something like that). Is the app not available for this version of the tv?
post #6034 of 8099
Yeah, thanks for reporting back. I did not get in on the low price, so I ordered the 4258 for $2 instead. It looks similar and is on that same list as the 3273 so hopefully it works.
post #6035 of 8099
I got it to work on the 5700. I think I got that message right after downloading and installing it. I either rebooted or waited a minute and tried it again and it was available, I can't remember exactly.
Some of the app worked terrifically, the magician holding out the crumpled dollar bill looked like it was coming out of the TV. However, at other times I saw severe ghosting or just couldn't focus at all on what was being displayed. Might just be my eyes, I've noticed I don't handle fast moving/up close 3D as well as my wife.
post #6036 of 8099
The 3D educational Apps are terrific!
post #6037 of 8099
Thanks for the reply. I'll keep on trying. I am 99.9% it can't be my bandwidth - I am using a wired connection and my speedtest.net is showing 59.21 Mbps. I guess I need to be a bit more patient with it. BTW - when you say reboot do you mean turn the tv on and off or something else?
post #6038 of 8099
Just turning the TV off and back on. I'm sure it's not your bandwidth, that's about 10x what I'm running at. Does any other network connected content work (Netflix, Amazon, etc?) And is your firmware up to date?
I remember having problems connecting to Netflix when I first turned the TV on, had to restart my router and then everything was good. Sometimes my router has difficutly picking up devices when I move them to a different wired connection as well.
post #6039 of 8099
VUDU works (and have to say the 3d trailers look pretty good for being compressed). Haven't tried the others. I did get the Update Firmware message when I tried to get into VUDU and it did update but can't confirm exactly which version I am right now. What I haven't done and will try tonight is restarting the router.
post #6040 of 8099
The LG factory tech was of no help. He acknowledged the clouding but said it is normal and nothing can be done. They are now sending an independent authorized serviceman.
Originally Posted by rxb2138 View Post
I am experiencing the same clouding/blooming issues and LG is sending their own tech Wednesday to check it out. Keep you posted on the fix.
post #6041 of 8099
Yes even I tried this calibration today and I noticed that Real Cinema is grayed out.
I also wanted to know if these calibration settings did give anyone a better picture?
These are the settings I am using now and think they are very good especially compared to CNET which is too dark. very vibrant colors.
I have not tried the THX settings as of yet.
post #6042 of 8099
Originally Posted by kenny23b View Post
Here's the settings from my 2 day old 55LW5600:
Local Dimming: 1
PSU Power: 0
Digital Demod: AT_BCM
Analog Demod: SANYO
Audio Amp: TAS5727
Backlight Type: EDG_LED
Thank you!
post #6043 of 8099
First of all, let me say hi to all of you. I will take delivery of new LW5600 tomorrow and I have a couple questions of this set. Btw I also had LH30 and also can access hidden menu with my logitech remote and I assume this should be the same on LW5600. I admit that I have not read the whole 200 pages in this thread but close to have and I didn't see any thing that relate to my question.
My question is about DVR feature which from what I understanding can record only OTA channel, now I have FIOS and I'm not sure if I can record some of premium channel like nat geo or discovery channel. Any one with FIos please confirm this to me.
Also if I'm able to record to portable hdd, will my laptop or WDTv live be able to read or see those files/video? What format LG record video file anyway?
post #6044 of 8099
Was anyone able to get Dual Play working? I saw online that LG cinema tv were going to role out dual play. What dual play is you can do full size split screen gaming. it allows each player to see their own screen by overlaying the images. Currently would have to switch some lenses around in the glasses but it seems the 3d option i needed is greyed out. Any tips on getting this to work or if other want to try it and get it to work let me know. I will do the same.
When my xbox is hooked up i only get the 2d->3d box lit up when i need the split screen 3d to show. any one know why the other 3d setting are greyed out.
youtube the following to see what i am talking about Dual view gaming (split screen Full screen!)-Any passive 3D TV can do it now!! COD Demo
post #6045 of 8099
anyone use PLEX? i set it up last night and when i try to stream a movie it stutters.. my pc is quad core with enough mem so its well over the required specs..
also.. i can play the movies on my pc to the tv using dvi > hdmi with it named PC so i dont get any sync problems.. however i have a 3d sbs sample and i hit the 3D button.. the option to select side by side is greyed out is there something i should rename the input to? i tried renaming the input to other things and all the options are greys out except 2d to 3d.
Did you ever get an answer to why the other otions were greyed out. I am looking into this as well.
post #6046 of 8099
Thanks for your response. I am hooked up from the PC via an HDMI cable. The PC is a Dell XPS 630 with an AMD Radeon 6850 video card.
post #6047 of 8099
i thought dual-play mode option is only available in the LG 55LW9800? are you saying that feature is also in the service menu for the LW5600?
post #6048 of 8099
i haven't found an answer.. i wish i could cause then i wouldnt have to worry about plex..
anyone have an idea?
pc DVI to HDMI.. 3d options are greyed out
post #6049 of 8099
I have seen some youtube videos that state that this is working on other models. I would image it would work just fine on this model if that option was not greyed out. all they are doing is selecting the splitscreen 3d option and using glasses with 2 right lenses and another with 2 left lenses. I would like to try this but cant seem to enable the split screen 3d option. the only option that is available is the 2d->3d the others are greyed out. these options are available for say 3d movie playback but not when my xbox is hooked up.
post #6050 of 8099
How do you have your xbox hooked and what game are you trying to play. I have mine hooked up with hdmi and the options are not grayed when playing gears of war played it 3d last night pretty sweet. going to try modding some glasses and see if i can do full screen split screen like the video
post #6051 of 8099
Right now my xbox 360 is hooked up via hd component cables as my xbox is old. I wonder if that could be it. I wonder if there is some setting on the xbox too that might help unlock this. So you were successful in getting the split screen thing to work? Very cool. i was trying this with gears as well
post #6052 of 8099
does anyone use PLEX to stream .mkv files? im having a problem and trying to figure it out.. i was testing a SBS mkv and it will stream and sound is there.. but it stops and seems to load every 5-10seconds.. my tv is connected to my wireless network using the wifi adapter.. wifi router is 5ft away.. everything else works fine.. hulu.. etc.. my computer is a quad core and way above required specs for PLEX.. its like it stutters and then catches up.. i really want to get this to work.. the computer is also hooked to the tv andi can play the files on the pc with no problem.. i have the tv going from geforce card dvi to hdmi however when i goto the 3d options to change it to SBS all the options are greyed out.. thus why i tried PLEX and when it streams a file the 3d options are there.. if i can find out how to get the 3d options from the PC HDMI input then i wouldnt need Plex at all
any suggestions?
I watch mkv files via Plex. My PC is hardwired and I used to have the 10 -15 minute play then buffer issue. It has improved a lot since I loaded the latest (I could find) version of Plex Media Server (0.9.5.0-dc1de23). I don't know if it was the combination of the server software or one of the many TV firmware updates that did it, but it has been streaming without buffering for the last two weeks. It might also be related to file size. The recent files have all been less than 5gb big. I'll try a larger file and report if it still occurs.
I'd bet that wireless is your problem. Have you tried using another DLNA server instead? Something like PS3 Media Server. Or try streaming a smaller (non 3d) file and see if that makes a difference. No clue on the GForce settings I'm afraid.
One question, if your router is only 5ft away, have you considered running a cable to your TV to eliminate wireless from the equation?
post #6053 of 8099
Originally Posted by fx72 View Post
The 55LW5600 is on sale at Frys for $1099. It is also available for shipping.
http://www.frys.com/product/6535443
Thanks so much for posting this info. Vann's delivery company lost my TV and now they are reluctantly issuing a credit. Went by my local Fry's and bought it.....WOO HOO! Saved me $170.00!
I'm going to pick it up in a truck. Ok to lay it down in the bed or does it need to be standing up?
Barry
post #6054 of 8099
Barry
It's not a plasma so no it doesn't need to be standing up.
post #6055 of 8099
Do you have a set of component cables for your xbox. If so could you see if you use them if the options are greyed out. If not no worries. I will see if I can borrow my brothers xbox that has the hdmi
post #6056 of 8099
I don't have the cables but I read somewhere that the xbox only passes 3d through hdmi. Also I did test on gears of war split screen and it does work you get full screen split screen
post #6057 of 8099
Hmmm...is your hdmi plug high speed? The 6850 does do 3d (this is what I am using) so not sure what else the issue could be. What resolution are you using?
post #6058 of 8099
Thanks for the info.. I will have to test this out... sucks that I was an early adopter to the xbox..... full screen split screen will rock
post #6059 of 8099
Barry
I emailed LG Canada on this issue, ie can the 55LW6500 be transported lying down or must it be in the upright position. Their reply stated that it must be transported in the upright position to avoid damage. I would play it safe and securely tie the box off in that position.
post #6060 of 8099
OK - lag was killing me on this TV. At times, it would lag, at other times, it would not show a sign.
I thought the HDMI 3 trick did it, but it didn't. BUT - I have been able to reproduce and fix the steps 100% with this method on ANY input.
Make sure the label is on PC!
Connect your console/PC to any input. If there is lag - power off the PC or console, wait a second, then turn it back on. Poof! No lag.
I play SBS 3D movies off of my HTPC, and when I enable 3D, the lag returns. Powering off the computer gets rid of the lag every single time. I tested lag with my XBOX 360 and sure enough, rebooting the console works.
It's sort of annoying to reboot after watching a movie, but whatever - it works. Hopefully a firmware update will come out to fix this permanently.
