Originally Posted by mrjktcvs
I had my unit professionally calibrated (ISF) by a guy that's been in the broadcasting biz for 4 decades. I sat there while he did it. He had a lot of positive things to say about this model. He had a negative experience trying to calibrate a Panny plasma the previous day -- the VT-30.
Aspect ratio: Just Scan
Energy Saving: Off
Picture Mode: Expert [1 or 2]
Backlight: 40
Contrast: 90
Brightness: 54
H Sharpness: 55
V Sharpness: 55
Color: 52
Tint: 0
TruMotion: Off
LED Local Dimming: High
--Expert control menu
Dynamic contrast: Off
Noise reduction: Off
MPEG Noise Reduction: Off
Super Resolution: Off
Black level: Low
Real Cinema: On
Color Gamut: BT709
Edge Enhancer: Off
xvYCC: Auto [grayed out]
Expert Pattern: Off [grayed out]
Color Filter: Off
Color Temperature: Medium
Gamma: 1.9
Method: 2 Points
Pattern: Outer
Red Contrast: -13
Green Contrast: 11
Blue Contrast: -23
Red Brightness: -1
Green Brightness: 0
Blue Brightness and all others: 0
Energy Saving: Off
Backlight: 40
Contrast: 90
Brightness: 54
H Sharpness: 55
V Sharpness: 55
Color: 52
Tint: 0
TruMotion: Off
Black level: Low
Real Cinema: On
Color Gamut: BT709
Edge Enhancer: Off
Color Filter: Off
Gamma: 1.9
Method: 2 Points
Pattern: Outer
Red Contrast: -13
Green Contrast: 11
Blue Contrast: -23
Red Brightness: -1
Green Brightness: 0
I tried these settings and i find them more better than these
HDMI 1 Input
ISF Expert 2
Energy Saving Off for Day Time ( Mimimum or Medium at night)
Range of Values based on user reports.
Backlight 41 (27-65) Higher setting causes wash out.
Contrast 87 (83-96) Higher setting casues white clip.
Brightness 55 (50-65) Higher setting causes wash out.
H. Sharpness 62 (62-71) 50 is neutral, higher may casue halos
V, Sharpness 55 (55-64) 50 is neutral, higher may casue halos
Color 50 (42-59) 50 is neutral, higher may casue color bleed
Tint 0
Expert Control
Dynamic Contrast Off (Try Medium for more pop. Low or High causes black crush)
Noise Reduction Off
Dig Noise Reduct. off
Black Level Low
Real Cinema Off
Color Gamut BT709
Edge Enhancer Low
xvYCC Auto
Expert Pattern Off (normaly)
Color Filter Off
Color Temperature Warm
Gamma 2.2
Method 10Point
Pattern Outer (Inner if you have no calibratone DVD )
IRE 100 Luminance = 115
IRE Adj. Points R, G, B
100 3, 2, -1
90 2, 4, -2
80 2, 3, -3
70 3, 1, -4
60 2, 1, -6
50 3, 0, -6
40 3, 0, -5
30 1, 1, -5
20 1, 3, -2
10 2,-1, 3
0 1,-2, 1
Color Man. System
Red Color -12
Red Tint -7
Green Color -15
Green Tint -6
Blue Color -6
Blue Tint 0
Yellow Color 7
Yellow Tint -15
Cyan Color 6
Cyan Tint 7
Magenta Color -12
Magenta Tint 13
Plus they even want to charge for shipping.
Just my opinion.
