I used to have my center channel speaker on top of my DLP rear projector, but that obviously wasn't going to work with a TV that's half an inch thick, so inspired by previous postings, I took a trip to Lowes and picked up some shelf hardware.
I hacksawed a shelf support standard in half and cleaned up the cut ends, then carefully drilled 1/4" holes to match the 15-3/4" spacing of the rear screw positions of the TV while placing the top slots of the standard halves at exactly the height I wanted.
I didn't want a long bolt in single-shear so I had to mount the standards "backwards" on the TV, and insert the brackets backwards to suspend the shelf slightly above and mostly behind the TV.
To get the front of the shelf as flush with the top front of the TV as possible, I (clumsily at first) routed out channels to recess it over the tops of the standards.
Unfortunately the screws that come shipped in the back of the TV only engage about 3 threads once they go through the shelf standards, so I'm not going to put the weight of the center channel on it until I can replace them with new screws that have a little more thread.
I'm not completely happy with how wobbily the plastic factory stand is, so I might end up replacing the whole thing with a steel stand, but I'll see how it is with the center channel on there. So far I'm only out about $20 since I already had a metal saw, dremel, drill, etc.
Enjoy...
Enjoy...
