I'm in the process of building an HTPC that is capable of Full 3D Blu-ray Video playback and bit-streaming Blu-ray Audio (DTS-HD, TrueHD, etc.). I'm going for the Sandy Bridge platform and won't be installing a Graphics Card, allowing Intel Sandy Bridge's capabilities of processing 3D Blu-ray Video/Audio.
I'm looking for suggestions to my current component list. Most specifically, I'm looking to avoid overkill - and if there's something that does a better job then what I have selected - I'm open to that suggestion as well.
Here's what I have so far:
- H67 ASUS or Gigabyte Motherboard (Approx. $100)
- Intel Core i3-2100 Sandy Bridge 3.1GHz ($129.99)
- Antec EarthWatts EA-500D Green 500W ATX12V v2.3 / EPS12V 80 PLUS BRONZE Certified Active PFC Power Supply ($69.99)
#Overkill: I'm wondering if I need anything over 380W.
- G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1066 (PC3 8500) ($79.99)
#Overkill: I don't know if 8GB is overkill or not; I figured applications like Media Browser/WMC would run faster/better with more memory.
- Thermaltake Black SECC Japanese steel LANBOX Lite VF6000BWS Micro ATX Media Center / HTPC Case ($89.99)
- Western Digital Caviar Blue WD5000AAKX 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive ($39.99)
Media is stored on attached eSata RAID Drives, so just need OS & Media Player Software on Internal
- Rosewill WMC Remote control/Rcvr RRC-127 for Win 7 ($24.99)
- Hauppauge Colossus HD-PVR High Definition H.264 Video Recorder ($129.99)
This one's for recording cable shows in HD .. DVR functions
Approx. $540 without DVR Card ... $670 with DVR Card.
