Originally Posted by
Noah
What you're seeing is likely not IR, but instead a separate phenomenon in which PDPs retain their last displayed image when immediately switching to a black screen. Even well-broken in plasmas that do not get visible IR will exhibit this issue from mere seconds of high contrast content followed by a black screen. What distinguishes this from IR is that it will be eliminated instantly upon displaying actual content and should not be visible with other solid color content, just black.
I wish there was a term for this (maybe there is, but I don't know of one) so we could call it something and distinguish it better from IR. I might suggest "black screen persistence" or something along those lines, since low APL content is required for it to be visible.
No, it seems like mild IR. My tv does it too, and it doesn't just go away the next time something is on the screen. It stays there for seconds or minutes during the displaying of other content depending on how long the IR image was there to begin with.
For example, on the ps3 xmb if I have Killzone 2 in the drive, and then go to the killzone disk icon so that the Killzone backsplash comes on the screen, the very bold white killzone title will remain on the screen after its gone even after it was up for only 5 seconds. If i get it, and watch 30 seconds of tv, then switch back to a black screen it is still there, only more faded. It will go away pretty quickly, but it forms very quickly too, and I would definately classify it as IR.
RandyWalters
I believe what he's seeing when the scene goes to black is Residual Charge, which is when the pixels go from bright to dark it leaves a slight ghost image visible in the black area, but is soon wiped away by bright content.
Phosphorescence is a sort of afterglow where you see the ghost images of previous content on the screen after you turn the TV off or switch to a blank-input/no-signal screen. All plasmas and tube TVs do this.
So is this a different phenomenon than IR, or is IR the same phenomenon of a different level?
