Originally Posted by Azuran
Well 72 Break in Hours so far on 50ST30, got bored and decided to try some gaming to test for lag. I play Tekken with friends often and can't seem to tell much of a lag with the few rounds I tested. I played an hour of Medal of Honor SP(PS3) couldn't tell of any lag present. I switched between Cinema w/ Motion Smooth on Strong and Off and did the same with Game Mode. Either my eyes aren't as sensitive as before or this set is a winner for gaming. I can't wait for break in to be over and see how it should look with a higher contrast. I DL'd the AVS 709 and will probably try my luck on that after 100 mark. Although I'm not that seasoned as far as calibration on any TV so If anyone has any recommendations for Cinema/Custom Mode settings after Breakin I'd appreciate it.
If you have a laptop Azuran, it'd be much appreciated if you could follow the instructions in the first post here and post your results.
