AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Official Panasonic 2011 TC-PxxST30 Thread [No Price Talk]
Official Panasonic 2011 TC-PxxST30 Thread [No Price Talk] - Page 252
post #7531 of 8347
Originally Posted by Dierkdr View Post
Congrats! Hope you enjoy the set: at its best - Blu-ray or HDDVDs - the 60" ST30 shows a Wonderful picture.
If you are stepping up from a smaller sized panel, and/or sit close enough to the screen (say around 9ft or less...), don't be SHOCKED if you find that a panel this large tends to Show Off ALL of the Inherent Flaws in whatever less-than-ideal program material you view!
Seriously thinking about moving all of our SD DVDs from the (basement) "home theater" to the LR, as our older 50" Pan plasma does a nicer job of Masking their PQ issues. (Our experience is that it takes about a 12 foot viewing distance with the 60" to roughly equal the Apparent PQ at 9 feet with the 50" - GIVEN SD Material....)
We've had 3 60" ST30s in house (plus 1 60" S30 - technically 2, but one had a cracked screen...), and ALL have been bothered by the Green / Pink (Magenta) tinting that characterizes 2011 Pan Plasma sets.
Our current set is a Nov Build 60" ST30, also from CostCo, and while it DOES have both Unwanted Green & Pink, it is still easily the Best of the panels thus far: with MOST programming, MOST viewers probably would not notice the issue, or would assume it is simply part of the material as opposed to a panel flaw. (Unlike the earlier panels, the Green on this one SELDOM tints Faces, instead showing up in background objects, where it is easier to ignore.)
Still, would recommend trying to rack up as many hours on the panel as you reasonably can before your 90-day return policy ends: although Green TENDS to get Better as the panel ages (at least up to 600 - 700 hours - the limit of our experience), you may find that the Pink/Magenta will grow worse over that same time period.
Also, other than Green / Pink issues, all of our panels have seemed to IMPROVE in overall PQ over the course of the first couple of hundred hours of usage or so. We kept the first panel the longest - around 700 hours - and it had noticeably Deeper Blacks and APPARENTLY more "pop" when we sent it back than any of the other panels have had. (IF you look at "letterbox bars" and find them disappointingly "gray" - instead of black - give the panel a while before getting too upset!)
And, while it is probably just common sense, we have also noticed that certain letterboxed material produces "Blacker" bars than other sources: TV - even "HD TV" - tends to be the worse, while MOST (but Not All) Blu-rays tend to be the best...
After 150 -200 hours or so, watch the blu-ray versions of "Dark Knight," the "Star Trek" reboot, "Iron Man 2," or the "LOTR Extended Version" - these should look Pretty Good NOW, but once the panel settles in they ought to look Great!
Best of Luck with your new panel!
Thanks for the reply Dierkdr. All seats are between 9.5 and 12 feet from the set. Yea I have read about your and so many others problems with the color (green,pink) on the ST sets. I know it is kind of a crap shoot with these sets. That is why the 90 day return really helped me make my choice on this set easy. I will have a while to decide if I want to keep it or get a ST50 if need be. I hope that is not needed but it is good to know that I have the time to change my mind if need be. I didn't want to waste the money so I bought the ST30, but I will spend the extra to get a ST50 if that needs to be done.
post #7532 of 8347
Echoes my thoughts almost to a "T" - with perhaps one quibble: if this latest (and LAST) ST30 does go back, will not be buying a ST50 until they have been out long enough to have established a Blemish Free reputation.
If, indeed, the 2012 panels are able to do so...
Perhaps time to reconsider LG!
Although, again, At Its Best, the 60" ST30 provides a wonderful picture: hard to imagine any other sub-$1200 2011 panel beating it for overall PQ!
(Green & Pink aside, of course!)
post #7533 of 8347
I hear what you are saying. I to would wait and see or jump at something else. To tell you the truth, I wanted a Mits. DLP since last summer. They to have had thier problems on the 2011 sets. Last summer the price difference between the two was much greater then it is now. So I spent alot of time in the Plasma and Rear Projection forums. So that would be another thought down the road as well for me when the 2012s come out. But really it shouldn't be this hard.
post #7534 of 8347
I'm in the same boat as you are, still deciding whether to keep my 65ST30 since I bought from Amazon and nearing my return period. Not able to decide if I need to wait for ST50 or stay with ST30, other than the standard def channels everything looks great, especially Bluray and HD DVD.
post #7535 of 8347
If everything looks great (no green/pinks) I am sure going to hang onto mine. I'm moving from a SD set (640x480) CRT 35" so this set should wow me with hi-def stuff.
post #7536 of 8347
Done with my break in. D-nice settings look awesome. Monsters inc looked unbelievable.
post #7537 of 8347
Congrats, I hope you feel like this. That is good to hear. Still waiting on my tv stand to get here and I will start my break in period.
post #7538 of 8347
Plug that bad boy in and get it started. You could have most of the Break In done.
post #7539 of 8347
I love this Tv. No Pinks No Green Blobs. No brightness fluctuations. AWESOME tv. I can't believe I got this for this price, especially when I paid over $2300 almost 5yrs ago for my Toshiba 52" LCD(Regza cinema series). You gotta love how you keep getting more for less money.
post #7540 of 8347
Without me having to read 7500 posts, can someone briefly explain the Green/Pink issue?
TV is set to cinema. November 2011 build date.
I have run my 60ST for just under 100hrs straight (zoom to HD channel, no letterbox) and I just now put a channel running I Love Lucy which is obviously a Black & White broadcast. The entire picture has a greenish tint to it and once in a while I notice little green flashes. My Panasonic LCD in the kitchen shows none of that and is clear and bright.
Is that what people are talking about, and if so, how do I go about getting it fixed?
post #7541 of 8347
I have run my 60ST for just under 100hrs straight.... and I just now put a channel running I Love Lucy which is obviously a Black & White broadcast. The entire picture has a greenish tint to it and once in a while I notice little green flashes. My Panasonic LCD ... shows none of that ....
Always assuming that you do not have the TINT control jacked out of shape, it certainly sounds like the panel has the Green Tint Glitch.
Of course, you DO understand that your panel is Working Within Specs; the Green Tint is only YOUR Imagination; You are being Overly Picky; and, gee, after all, Who Actually Watches Black & White Programming any more?!?
There is no fix. You can return the set & try another panel. The new one will also have Green &/or Pink (Magenta) Tints, BUT perhaps not as badly. (Our latest panel, a Nov Build ST30, shows both flaws, but is the best of the 4 Working 60" panels we've actually had at home.)
At last count we were up to something like 21-out-of-21 2011 Pan Plasmas Tested, with ALL of them exhibiting the problem to one extent or another.
Unless you are approaching the end of your Return Period, 100 hours may be too soon to give up entirely on your current set: you may find that the green will diminish in visibility as the panel ages over the first several hundred hours.
You can also Lessen The Visibility of the Green by playing around with the picture settings. Alas, CINEMA gives by far the BEST overall PQ on these sets, but moving to Custom opens up additional controls - panel brightness, 2 point color balance controls, gamma controls - that can help mask the Green tinting, albeit at the cost of other PQ factors. (However, if you pick up Pink you are stuck, as "fixing" one tends to "Enhance" the other.)
A good Professional Calibration also seems to help hide the Tinting.
The 60" panels also seem prone to Pink/Magenta tinting, and THAT problem is more likely (then the Green Tinting) to become MORE visible as the panel ages. We kept our first set in house for around 700 hours, and finally sent it back due to the Pink Problem: Green was still visible during some programming, but we probably would have lived with it in the absence of the Pink/Magenta. On that panel, the Pink started out as Barely Visible "highlighting" at the extreme R edge of the panel - but then grew dramatically as we aged the panel....
The Green Tint Glitch was initially reported as "Green Blobs" - and suspect from your description that your panel has one or more actual "Blobs" as these often show up as "Flashes" of green during B&W (AND OTHER!) programming.
The BLOB is merely a More Intense Area of the Green Tint, and, as such, is more readily visible. On the "best" panels, the green tint assumes a more uniform appearance, which makes it harder to spot in Bright / High Color scenes. Perhaps because of the blobbing effect - or simply slight variations at the Gray Level within which the Green Tint is most obvious - some panels show significant Green Tinting on FACES, given a Slightly Dim Scene (and/or a somewhat darker complexion, or beard stubble).
Our first 3 60" Panels showed significant Facial Discoloration, and, of course, this Highlights the problem: Almost everyone knows that Faces should NOT be Green! Our current panel apparently pushes the green to a lower point in the gray scale, and faces SELDOM look "Green" - makes the problem much easier to Live With.
Spouse thinks this set looks "fine"; I will wait at least another 30 days before deciding (we still have over 60 days before the end of our Return Period....).
Age your panel as quickly as you can, before the return period expires, and make your decision at that point. Have found that saving selected scenes to our DVR, and then photographing them (using same panel & camera settings) is the easiest way to track progress over time, as well as from panel to panel...
Best of Luck.
post #7542 of 8347
I did most of my break in sitting in the bottom of the shipping box. Just made sure the plastic was pulled down enough to clear all the vents. I didn't have anyone to help me until later to hang it on the wall.
post #7543 of 8347
Have not touched any of the colors at all, yet.
Just delivered the other day. Took 3 weeks for Costco to get it from Atlanta to TN. But that's another story.
I will be trying D-Nice' settings which is why I burned it in for several days straight. As for the pro calibration, I am a minimum of 1hr away from anything resembling a real town, so that's pretty much a no go.
The greenish tint is throughout the whole picture. It just seems to make the black & white a little "off" looking.
Costco has the 90 day return policy, but the problem with that is that no 2011 tv's at great deal prices will be left.
Thanks for all the info.
post #7544 of 8347
Like the rest of us that bought at the end of the 2011 production run. If and when, we are not happy with our sets. We will be moving on to something else other then a ST30 model. Which means more $$$
post #7545 of 8347
Thanks for the push kwaidonjin. I am starting Break In today
Thanks, that's what I will do as well Carey P.
post #7546 of 8347
Do these sets have the ability to custom name inputs ?
HDMI1 = XBox360
HDMI2- Blu Ray etc ?
Looked online at the manual and didnt see it.
I have two xboxes and an HDMI switch would help cut down on potential confusion.
post #7547 of 8347
HDMI1 = XBox360
Click menu,setup,input labels.
Old Mike
post #7548 of 8347
Played MW3 for about an hour and a half last night, all free for all. Did not see one sign of IR, I did turn the Contrast down to about 65 though in game mode.
post #7549 of 8347
I have reviewed this entire thread and done a number of searches but wanted to connfirm something. The GT and VT fbr issues can be corrected via a 2.1 patch, which is downloaded from Panasonic's website and installed via a SD card. Am I correct that the ST line does not have a similar fix and that the only way the fbr issue can be corrected is via a Panasonic A board swap?
post #7550 of 8347
^The information is in my signature. The information you stated is not correct.
post #7551 of 8347
Yes, I have read the info in your post many times. I see one must call Panasonic. Is there a way to download the patch myself to a SD like with the GT or VT patch? If it is in your info I am sorry -- I am just missing it as I read and reread the info several times. Any help you can provide would be apreciated.
post #7552 of 8347
New to this forum (so new that I actually posted this on the VT thread), a BIG thank you to all of you who post this awesome information. I have searched this forum and read through MOST of the posts to this thread. So, I apologize in advance if someone has already posted on the topic I have a question about.
I waited and finally pulled the trigger on the Panny 55ST30, I own 2 other Panasonic Plasmas, so I was confident in the decision, but wanted to wait it out until the FB issue was resolved. Fast forward 9 months to last week and unboxed this wonderful display.
Nov 2011 build, but SN is xx1205xx
I notice, really only when watching sports (basketball and hockey) the screen flicker, as if someone in the room with me just took a picture with the flash on....at this very same time, the screen brightness changes (lighter or brighter mainly, occasionally darker) Would this be part of the FB issue?
I read the link on tfoltz's signature and he talks about viewing basketball and hockey games, so before I call to begin a claim...would someone be able to chime in on my issue if I have accurately described it??? Its pretty annoying, but really only visible when viewing sports (which is my main viewing content) I hate to get all worked up if this is a normal issue, and if so, is there a way to lessen the 'noticeability' of it?
I recorded the same content on all 3 of my plasmas, yet only notice the flicker / flash on the ST30?
thanks guys!
post #7553 of 8347
There is no downloadable FBr patch for GT or VT, which is why it is not discussed in my signature. You want something that doesn't exist.
post #7554 of 8347
I was able to download and correcct fbr on my 65GT30 -- to an SD card and a link to Panasonic's site. I cannot find a similar link for a ST fix. I will locate the link and include it so you can see.
EDIT: Follow this link and go to post 243 -- it contains the download for correcting GT and VT fbr issues. http://www.avsforum.com/avs-vb/showt...1340522&page=9
post #7555 of 8347
If you say so. Good luck.
post #7556 of 8347
Cut and paste this link and you will see the GT and VT series covered -- and dozens of posts in the GT owners thread on correcting fbr via the downloadable patch and an SD card.
I was just curious why a similar fix is not available for the ST line.
http://panasonic.jp/support/global/c.../down_pro.html
post #7557 of 8347
The FBr patch, which is not downloadable, is different than the 2.1 color luminance downloadable patch for the GT30 and VT30. That patch does not exist for the ST30, and again has nothing to do with FBr.
Edit: You can go into the GT30 thread right now and see people discussing it. Zero owners have patched FBr via downloadable firmware.
post #7558 of 8347
thanks guys!
Assuming you are using Cinema or Custom picture settings with CATS off, it's source related and has nothing to do with your TV. Standard setting and/or CATS introduces fluctuations. All of my TVs show this on basketball and hockey, the ST30 being most noticeable because it is the largest TV I own.
General rule: If you don't notice a problem while watching high quality content (blu-ray), then any issues you see when not watching blu-ray are due to the content you are watching.
post #7559 of 8347
Thank you, I was hoping you would shoot a response my way.
Yes, Standard mode (out of the box settings) the flicker or flash is the MOST noticeable, followed by the brightness on the screen increasing (brighter)...but sometimes goes darker. Cinema and Custom show less flicker / flash and CATS is off on all 3 modes I've tested. Can't seem to find any flicker or fbr on other content (bluray, DVD, etc) or even Dish programming (aside from bball and hockey games)
I read through hundreds (literally) of posts on here and that was one of the first things I changed. I didn't want to ask a question that was already asked 100 times over, since I am sure you all get sick of that (can't tell you how many times your signature was referenced...I didnt want to be that guy)
I was afraid with the older Serial number 1205 and not the 1213 or higher, that mine MIGHT be experiencing the very same thing I waited 9 months to avoid.
post #7560 of 8347
Guess I was lucky that I bought my ST30 in March 2011 and never experienced the flickering/brightness issue that alot did and I've seen videos of it on Youtube so I know what it looks like.
