Originally Posted by Shinyav
Got a question for st30 owners.
I have had my TV for almost a year now. However, recently I have begun to notice a greener color to some scenes that have grayscales such as fog and shadowy scenes.
The best way I can show it is if I put up a grayscale from the avshd709 disk there is green bands going top to bottom at certain shades of gray. Depending on brightness and other calibrations they will shift from left to right.
I have tried this through a HTPC, USB drive to the side, and a burnt dvd. All have the same effect. However, on the HTPC if I bring it to another monitor it does not show this problem. So I am almost 100% sure its something with the TV.
I calibrated grayscale using 10point measurements and was able to get them all under a delta of 5. However the problem still exists.
It is very subtle and most people would call me crazy for even pointing it out... I feel like everyone here would understand my concern though.
It doesn't seem to show up on any slides of solid color, at least at 5% intervals, so I don't think its the green blob problem other people have mentioned.
Has this been documented anywhere else? Anyone hear about this type of behavior? Any suggestions on what to do?
I may be experiencing something similar. Have you also noticed any red banding along with it? I made a thread recently regarding something that I was noticing with brightness and blacks, and after play around some more with my htpc and some tools that can adjust gamma, I've begun to conclude that the gamma at lower ire's has risen. When I boost gamma at lower ire's it seems to fix the banding issue. I've only done some eyeballing as I loaned out my D3, but I'm beginning to suspect that either my A board is going bad or that these TV's are programmed to make some sort of adjustment after you get so many hours on them. Read my thread if you want more detail about what I noticed initially.
Edited by ttnuagmada - 12/15/12 at 6:41pm
