AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Samsung going to the dump or can it be saved?
post #1 of 4
Need some help, my Samsung LN32A300 recently started doing this. I checked all the ribbons and swabbed them with alcohol no change.
Is my LCD going to the dump?
post #2 of 4
Does it have the same problem on all inputs, including the built-in tuner (if it has one)?
The problem appears to be in some colors more than others, so it may be repairable. It would not hurt to ask a shop if you have one nearby, or to sell it as-is on Craigslist otherwise.
post #3 of 4
Yes it does it with all inputs.
post #4 of 4
I have the same problem, did you figure it out?
