AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Samsung UNXXD8000 Owners' Thread
Official Samsung UNXXD8000 Owners' Thread - Page 231
post #6901 of 8401
Hi guys,
After reading this thread I went out and bought a 55" D8000. So far I am very impressed with everything apart from the most important bit, the 3D.
I get this ghosting effect on most things. It is most prominent on graphical text on sky sports on the sky 3d channel. The snooker happened to be on when I took this.
This was taken with my iPhone through one of the lenses on my 3D glasses. As you can see I get a repeat image to the right of the main image. If you look through the other lens you get a repeat image on the other side.
The outcome is when watching, obviously with both eyes, I get repeat images on both sides.
If you look closely (not visible on the pic) you can see the ghosting on the snooker balls / football players / anything watched in 3D.
How do I solve this?
Cheers
post #6902 of 8401
My UN55D8000 arrived this morning....purchased from Newegg last Wednesday. I went ahead and set it up before I left for work but didn't bother to turn it on since it was still quite cold. I'll head home at lunch and make sure it works.
Cosmetically, it looks flawless. Very happy to see it arrive undamaged.
Quick check on the back panel showed it was manufactured in December 2011 with an H303 panel so happy to see that also.
Looking forward to testing it out later today.
post #6903 of 8401
What are the best wall mounts for the 8000 series LEDs? The Samsung mounts look appealing due to their slim profile and the fact you don't have to tear up your walls too badly installing them.
http://www.samsung.com/us/video/tvs-...s/WMN2000CX/ZA
Any other options?
post #6904 of 8401
1920 x 1080 @ 60i HZ
The above is what I got when I hit the info button on the remote on my D8000. I returned that set. Isnt it suppose to say @60HZ what gives? Every Samsung LED or Plasma I've ever had was 60HZ? Where is the i coming from?
post #6905 of 8401
Any other options?
All the mounts work for this set I bought mine from Costco, it's perfect.. You can get either one they have, the one that comes out from the wall and turns left or right or just the straight mount. You don't need a proprietary mount they all work perfectly..
post #6906 of 8401
I finally took the plunge yesterday and bought the UN60D8000 at Fry's.
Lo and behold, the panel I ended up with had some major backlight bleeding issues.
It is extremely annoying and visible, especially when watching a dark movie like, say, Drive.
I have tweaked the backlight and brightness settings to no avail.
Yup, it's the H301.
I'll be forced to exchange the panel.
Has anyone had experience exchanging TVs with Fry's?
More specifically, can they take back the old one when they deliver in the replacement model?
It's a huge TV and I can't holler it back to the store...
post #6907 of 8401
Yup, it's the H301.
Do they even have an H302 or H303 for the 60 inch model? I have only gotten H301 october and november builds when i had to do exchanges.
post #6908 of 8401
I meant to put H301 from October.
I'm myself not sure if there is a more recent build than the November one.
post #6909 of 8401
Originally Posted by Jerry98vert View Post
Of course MKANET is very nice to talk to all, I tried his settings and I just don't like Movie Mode doesn't give me the WOW factor. Try mine I know it is bright but man the WOW is there:
Picture mode: Standard
Backlight: 16
Contrast: 98
Brightness:55
Sharpness: 42
Color: 51/49
Advanced Settings
Black tone: Darkest
Dynamic Contrast: High
Gamma: -1
Expert Pattern: Off
RGB: Off
Color Space: Native
10P White: Off
Flesh Tone: 0
Edge Enhancement: On
Motion Lighting: Off
LED Motion Plus: Normal
Picture Options
Color Tone: Cool
Digital Noise Filter: Auto
MPEG Noise Filter: Auto
HDMI Black Level: Normal
Auto Motion Plus: Clear
Film Mode: Auto2
Smart LED: Standard
Cinema Black: On
I am telling you someone should try these settings might be a bit bright but it looks nice.
post #6910 of 8401
I have the 60inch model with the H301. My set looks fine. Was there a problem with the H301 build?
post #6911 of 8401
Once you change the contrast just throw all MAKnet settings out the window.. The set is wow already his settings are perfect.. Contrast is the 1 setting you can't touch or all the hardwork is pointless..
post #6912 of 8401
hey guys, i got this television a couple of days ago (un46d8000) and i am very pleased with it. i tried applying some settings i found on this thread, however, when i turned the set on this morning, they did not save for some reason. is there a 'save feature' or something that i need to enable?
post #6913 of 8401
Originally Posted by ditrasetman View Post
What type of tv set do you have? Do you notice that even with AMP on clear, although it removes most of the judder, for certain scenes where the camera is panning (like panning over a landscape - with all of the pixels being in use), there is still some small judder (that most people would not notice).
55D8000, I do notice some judder on clear but it is random. I can't say I have seen it when the camera is panning. But it's so infrequent that it doesn't bother me.
post #6914 of 8401
You probably changed the input maybe? So if you switch form HDMI 1 to HDMI 2 the settings stay according to input or movie vs standard etc..
post #6915 of 8401
Originally Posted by john121park121 View Post
Hi guys,
Cheers
Any ideas guys?
post #6916 of 8401
ahh, that's probably what happened. i switched to hdmi 2, where i have the ps3 connected to watch a movie.
so, i would need to manually make these changes for each and every input?
post #6917 of 8401
You returned the set cause it said 60i HZ? What for? (American or UK model?)
post #6918 of 8401
Originally Posted by DarkNessBear View Post
I have a question that has been perplexing me for some time.
How come an LCD/LED w/ motion smoothing; 120hz or 240hz. Has the Soap opera effect, yet my plasma 600hz does not? And this is with "motion smoothing" on High/Max on both displays. Shouldnt the Plasma be a bigger offender?
And for the record. I love the Soap Opera effect.
Anyone have any reasoning for this?
post #6919 of 8401
The reason you are seeing the 60i in the info box is because the info box only displays the signal's actual Hz and screen resolution and not the info of the picture on the screen after the TV processes it. Meaning that the 60i you are seeing is the signals actual specification and not the screen's specification. Currently there is no way to display the screen's specification in the info box since those specs are constant.
post #6920 of 8401
Hi, jazzdpb,
Yes.
The settings for each HDMI port belong only to that port.
Hope this helps.
OldAKGuy
post #6921 of 8401
My 60 inch October panel is H301 and I don't have issues. There may only be H301 panels used for the 60 inch. I think the panel version may be a red herring. Don't return a set based on that.....
post #6922 of 8401
I'm not returning it based on that, I'm returning it based on the terrible backlight bleeding.
We shall see if the problem is minimized with the more recent display.
post #6923 of 8401
Any ideas guys?
Nope, but I suffer from the same issue myself. I haven't gotten around to calling Samsung just yet, but I'm definitely going to do so. All my movies look like that, as well as my games. Received Sanctum 3D today, and that was horrible too. I've done a fair bit of troubleshooting to no avail, and now my last resort is Samsung.
post #6924 of 8401
Its American model, I returned for a C8000 which to my eyes had a 100% better picture. But no 60i HZ was not the reason I returned it. Just curious as I've never seen a 60i HZ.
post #6925 of 8401
These are my settings which is similar to yours, differences in magenta. Still working on it but as a disclaimer, most of our viewing is in a not well lit room since the the cieling light is right by where my wife sits, so the settings might seem a little high for some. But I can distinguish different dark colors, purple vs black for example, when they are up against each other. These are strictly eyeballs and somewhat carrying over from the BR player on another input.
Backlight: 15
Contrast: 86
Brightness:43
Sharpness: 20
Color: 52 (yours was missing)
Tint: 50/50
Advanced Settings
Black tone: Off
Dynamic Contrast: LOW
Gamma: 1
Expert Pattern: Off
RGB: Off
Color Space: Native
10P White: Off
Flesh Tone: 0
Picture Options
Color Tone: Standard
Digital Noise Filter: Low
MPEG Noise Filter: Off
Film Mode: Auto1
Smart LED: Low
Cinema Black: Off
post #6926 of 8401
Finally mounted the tv! Really like the samsung design on wall mount
post #6927 of 8401
Any other options?
Hi, I would highly recommend you look at the wall mounts at monoprice.com. Search for 8588, I believe this is the one I'm using for my UN60D8000 and it's overkill. You can hang on it without fear of it breaking, it probably doesn't even notice the tv is there.
post #6928 of 8401
Backlight: 15
Contrast: 86
Brightness:43
Sharpness: 20
Tint: 50/50
Advanced Settings
Black tone: Off
Gamma: 1
Expert Pattern: Off
RGB: Off
Color Space: Native
10P White: Off
Flesh Tone: 0
Picture Options
Film Mode: Auto1
Smart LED: Low
Cinema Black: Off
Thanks for the work will check it out tonight, I will get back to you.
post #6929 of 8401
Originally Posted by OldAKGuy View Post
Hi, jazzdpb,
Yes.
Hope this helps.
OldAKGuy
thanks for confirming.
i went ahead and changed the settings for both the xbox and ps3. now the dark knight doesn't look like it was shot on a camcorder.
post #6930 of 8401
I too have a 60" H301. Does anyone have a H302, H303 or H304 on the 60" model? If so, please let us know!
Also, for my friends with the 60" H301 model - do you guys also notice some mild stutter/judder on your sets?
