Originally Posted by
starstreak
No replies yet to my questions below?
I have another question, this tv is supposed to be full array micro dimming? Or is that different things? I keep reading stuff that's it's edge lighted but if so, then it can't be full array, right?
The screen is glossy &reflective I have some glare from the two windows on either side of my front door I have a frosted window application on these for privacy.
Samsung UN55D8000 Provides Incredible Contrast with Micro Dimming Plus
Micro Dimming Plus is unique feature on Samsung LED UN55D8000. TVs typically treat their light source as a single light even though there may be many bulbs making up that light. While most TVs can vary the brightness, they expose the whole scene to the same light. As a result, a bright object in a dark scene (a candle in a dark room) is dimmed to make the room dark, or a dark object in a bright scene (an action hero silhouetted against an explosion) is grayer than it should be to make the scene bright.
With the advent of LED TVs, this was no longer a limitation of TV. LED light sources can be placed behind the panel and used to light only a specific region. With many of these LEDs behind the panel, bright areas get the light they need and dark areas stay dark. This is a process commonly called "Local Dimming".
However, Local Dimming poses other problems: the TV must be thicker and more LEDs are needed making the set more expensive and less energy efficient. Samsung has found a way to create the contrast improvements offered by Local Dimming without sacrificing the TVs depth, design, energy efficiency or price. This innovative technology is called Micro Dimming. It uses software to analyze the picture, break it up into many squares, and adjust the panel to account for darker and brighter areas. On the LED 8000, this is taken even further with Micro Dimming Plus.
In addition to the Micro Dimming software, the LED UN55D8000's Micro Dimming Plus features built-in hardware that allows for each of the LEDs lights to be automatically adjusted independently. If you are looking for elite picture quality in an ultra slim TV, Micro Dimming Plus in the Samsung UN55D8000 ensures that the image is as close as possible to what the camera saw when the video or film was made.
List Price: $3,000.99
Samsung 55-Inch LED TV UN55D8000 Now on Sale at Amazon.com
at 9:30 AM
Email This
BlogThis!
Share to Twitter
Share to Facebook
Labels: Micro Dimming Plus, Samsung, UN55D8000, UN55D8000 Features
Newer Post Older Post Home
