AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Onkyo TX-NR807 Remote Codes
post #1 of 2
Hello All,
I"m trying to see if there is a code available so that I can power on/off my Optoma HD200X-LV with my Onkyo NR807 remote control. My Onkyo user's manual very clearly states that I can find remote control codes organized by device type. No such codes are present in my user's manual or in any sort of separate document.
Does anyone even know for sure whether or not the Onkyo rc can be synched up with a projector? When I went through the basic procedure of synching my different devices, most went quite smoothly. One thing I noted, however, is that there is no allowance, per se, for a projector--instead, if projectors are 'allowed', it would seem you have to find them under TV. Or am I missing something?
I have sent an email to Onkyo's reps in Canada, but they have not replied.
Can anyone help?
Shaggy
post #2 of 2
did you ever get a reply to this from Onkyo? I have the same problem
  Back to Forum: Remote Control Area
