AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Need a receiver for my paradigm monitor 9
post #1 of 8
I am looking for a 500-1000$ receiver to drive my new monitor 9, cc-290, Adp 190 x2 and dsp3200 sub.
I would like dual hdmi outputs since I will use it for an epson 8350 and a new tv. It will be used 50 50 for gaming and movies.
- 5.1 or 7.1
- hdmi 1.4
- network feature is a plus
I had the denon 3311 in mind but I find it a little expensive.
I would appreciate your suggestions!
Thank you
Mark
post #2 of 8
I would suggest looking at Onkyo! I have the monitor 11's, cc290, adp 390's and the dsp3200. Pretty much the same setup and I am driving them with the Onkyo 807! The new Onkyo 808 would be a great avr for your system! I'm actually thinking of upgrading my avr. Onkyo and paradigm sound amazing together!
post #3 of 8
I have 10+ yr old Monitor 9's and the only thing that drove them was at first Onkyo, then Integra, a DTR 8.2 for 7 yrs. and now a brand new DTR 40.2. Onkyo/Integra is an excellent match for the Paradigms. I might suggest since your budget is inbetween $500 and 1K look into the Integra 40.2 which retails for 1K but can be had for way less. If you have even a fleeting interest in internet features look at this receiver! I'm just blown away by how many Internet Radio stations I receive with my new Integra! Hundreds of V-Tuner Radio stations and Pandora (40hrs free a month) and a trial sub to Sirius Internet Radio (1 yr) This new Integra has made my Monitor 9's come alive again!! And the setup is very user friendly!
Jeff
post #4 of 8
I'm in the same boat as you I have the 9's and CC-290 and am looking at a new receiver as well. I currently have a Yamaha 663 but my short list includes the Denon 4311, Integra DTR-70.2, DHC-40.2 and 80.2 and the Onkyo 3008 and 5008. I can go either route as I am running amps as well.
post #5 of 8
There is an extensive discussion on blu-ray.com on the DTR 40.2. Eric, look into the DTR 40.2, it has preouts for seperate amps, way less than the 70.2.
Jeff
post #6 of 8
Jeff
One thing I really want is MultEQ-XT32.
post #7 of 8
I am tickled pink (not elmoy...) by the MultiEQ. What does the XT32 do above and beyond the MultiEQ?
Jeff
post #8 of 8
Jeff
More filter resolution and SubEQ-HT for calibrating two subs.
http://www.audyssey.com/technology/multeq.html
http://www.audyssey.com/aboutus/pres...y-now-on-avrs-
