AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Wichita, KS - HDTV
Wichita, KS - HDTV - Page 103
post #3061 of 3098
Well, it looks like they've made the final move from SD 16x9 to HD.
post #3062 of 3098
As mentioned in the HDTV Programming forum, Trio Whole Home DVR is now available in Kansas.
http://ww2.cox.com/residential/kansa...lehomedvr_1210
post #3063 of 3098
I was scanning my TV to find out that KSAS (Fox Kansas) and KMTW (MyTV Wichita) now has subchannels. Right now they have The Cool TV from Cool Music Network from Lawrence, KS.
24.2 - TheCoolTV - Pop Power
36.2 - Country
Plus, Newport Television (owners of said stations) and Gray Television (owner of KAKE-TV) have a deal with Weigel Broadcasting to show MeTV as part of their stations subchannels. I wonder who will get it here in Wichita?
post #3064 of 3098
While every other affiliate is listed on the MeTV website, in Wichita, it says "TBD."
Go figure.
- Trip
post #3065 of 3098
I'm seriously considering a HD Home Run Prime
http://www.engadget.com/2011/05/02/h...ailable-for-p/
But the last time I used a CC device on Cox it was a nightmare. I was paying the same for the cable card that I paid for the box and it rarely worked right and channels would randomly go missing.
Has this changed at all?
post #3066 of 3098
I have two cable cards, they are $1.99 each per month. They work perfectly.
post #3067 of 3098
What do you use them with?
Do you get all channels?
Do channels come and go?
Do you get to use any of the on demand stuff?
post #3068 of 3098
What do you use them with? I have a Tivo Series 3 DVR
Do you get all channels? Yes, except the on demand channels
Do channels come and go? No
Do you get to use any of the on demand stuff? No. Cable cards are only one-way devices.
post #3069 of 3098
Thanks for the reply (again)
I thought Cox here in Wichita was using or was planning on using SDV which meant one way devices were not going to be compatible. I'd have to invest in some hardware that will be rendered useless if Cox makes that jump.
post #3070 of 3098
There was talk of Cox going to SDV a few years ago but I haven't heard anything for a long time. If they do go to SDV, they will be required to supply you with a Tuning Adapter so you will still be able to use your cable cards.
post #3071 of 3098
Question HD quality on Cox vs. Direct tv...
I made the switch to ATT's UVSERSE a couple of weeks back and noticed IMMEDIATELY they were compressing the hell out of their HD. Called and cancelled a week later and went back to Cox. Now I'm getting the itch for Direct TV. Can anyone comment on Direct TV's PQ vs. Cox? I have absolutely no problem with Cox's PQ it's fantastic, just getting a tad bit expensive....
Oh, and what about signal loss in bad weather?
Thanks guys.
post #3072 of 3098
Thanks guys.
I used to have Direct TV, but never with HD. Signal loss in bad weather was common. Heavy rain was the biggest problem, however in winter, ice and snow buildup on the dish would kill the signal as well.
post #3073 of 3098
On Friday my inlaws got the whole home DVR system. This is the internet so let's focus on the negatives first.
  • The in home install was a rip off. There was no cable ran (and he wouldn't wire up additional rooms). I hooked up the boxes to the TV as I didn't want him messing with my hard work (and all we had to do was unplug the old boxes and plug the new ones in). To top it off the installer knew nothing of the system. Even if I do get this I won't until I can do a self install.
  • You can't pause live TV on the secondary boxes. I realize now that they never say you can but they sure do hint at it. If you want to pause you have to start recording and then go to the recording. Bleh.
  • I was so hoping that we would see an interface improvement and we really didn't. This java based Cisco system is just as slow in responding as the old Motorolla boxes.
  • Just like the old motorolla boxes, these boxes have neutered connections. There are hookups for USB and other such fun stuff but they are all disabled.
  • The clock on the front is absolutely worthless. A small thing (no really, it is small) but in their main room this was the main clock! Oh well.
  • The new UI isn't bad but it isn't good. All and all I'd call it a wash compared to the old UI. Some of the fonts are smaller and some are bigger but thus you get less information on screen. When we have great 8ft UI examples out there you would think the Cable companies could get their act together here. At least it doesn't have advertisements in the guide!
But there is some good
  • At least you can watch / set recordings on the other boxes. It isn't as nice as I would have wanted but better than nothing.
  • The boxes don't put off near the same amount of heat.
So when I get cable again in the fall I will probably be looking at some of the alternatives that are popping up out there instead of going with this limited and expensive route.
post #3074 of 3098
My biggest frustration (from a usability standpoint, stability is a whole new animal, that and the install fee.) is the fact that side by side, my new "Trio" WIDESCREEN guide shows the EXACT SAME amount of information as my old Fullscren guide. They took zero advantage of the added screen real estate, and just moved stuff around. Can you not show me an extra hour of programing and push the Program info to the top like it used to be?
Currently all of the Boxes in my house have no guide data, makes watching TV a PITA, and Cox, like always, has no answers for me.
post #3075 of 3098
KAKE-TV is making the transition to HD. Here is the link:
http://www.newscaststudio.com/blog/2...-on-hd-switch/
post #3076 of 3098
So I decided to go with Direct TV. So far so good. I'd recommend to anyone wanting to save money from Cox, plus there whole home DVR software is light yrs ahead of Cox at the moment. Pic quality slightly worse than Cox but 10x better than ATT. If you care about your HDTV's diet stay far far away from ATT.
Now if only Direct TV would get AMC-HD in time for Walking Dead season 2....
post #3077 of 3098
As of Sunday (July 17th), KAKE News is now in HD and they changed their moniker from KAKE 10 to KAKEland....
http://www.kake.com/home/headlines/K...125734328.html
post #3078 of 3098
I ditched the box and between now and when my network tuner gets in I'm just using ClearQAM. Like everyone else my TV found dozens of non channel channels.
Is there a current list of the Cox ClearQAM chans?
post #3079 of 3098
Ok, this is a moot point because all of my ClearQAM chans are gone this morning. I just need to go into a cox store and cut the cable completely.
post #3080 of 3098
But even KMCI won't add The Cool TV as a digital Sub Channel and the station is in KU hometown and I guess KOMU would add it to replace Universal Sports Network.
post #3081 of 3098
I recently moved from Kansas City to Garden City. I have Directv and was told I would get local channels in HD out here however that is not the case. Any recommendations for best antenna to hook up out here to get ABC, CBS, FOX, and NBC in HD? Thanks!
post #3082 of 3098
Well, in Garden City you are not going to get FOX over the air because there is no FOX transmitter in the area, so far as I know.
For the rest, you will need a low-VHF and high-VHF antenna, probably a roof antenna, aimed probably to your southeast. I'm not sure if the CS600 is a large enough antenna to get CBS reliably, though I would think that it should be.
- Trip
post #3083 of 3098
Not entirely true at that point (or even right now). Only the weather segments of KSN's newscasts are in HD while the rest (including the studio newsdesk shots) are still in 16x9 SD.
post #3084 of 3098
Thank you Trip! Appreciate the help.
post #3085 of 3098
Take a look at tvfool.com. They offer a map that allows you to plug in your address and view coverage of OTA signals in your area.
post #3086 of 3098
That's going to be tough probably. Think big, think high I would guess. Maybe a rotator. Check out AntennaWeb.org,
http://antennaweb.org/aw/welcome.aspx
post #3087 of 3098
51-1 51.1 480i DD2.0 KSMI Universal Sports (Soon)
51-2 51.2 480i DD2.0 KSMI My Family TV (Soon)
51-3 51.3 480i DD2.0 KSMI Biz Television (Soon)
51-4 51.4 480i DD2.0 KSMI Live Well (Soon)
post #3088 of 3098
Has anyone ever used cable card in addition to a whole home DVR setup w/ Cox in Wichita?
None of the SD channels are being picked up and a lot of HD channels (basically anything not local) is showing as not having a subscription.
post #3089 of 3098
This week Cox Kansas added 4 new HD channels...
HLN (Headline News - 2026)
TruTV (2064; Was on temporarily this year for the NCAA Tournament)
TCM (Turner Classic Movies - 2054)
OWN (Oprah Winfrey Network - 2051)
post #3090 of 3098
DISH Network added the HD feed of KSCW on March 28th
