AVS › AVS Forum › Audio › Receivers, Amps, and Processors › denon 3311ci vs onkyo nr708
post #1 of 3
The Onkyo is $200 cheaper (after paying Denon $50 for iPhone control firmware upgrade).
Except for the $200, is there any other reason why I should not buy the Denon?
post #2 of 3
There is no other reason to prefer 708 over 3311 other than price. Denon is all around better unit.
post #3 of 3
The Denon 3311 offers the more advanced version of Audyssey MultEQ XT (vice MultEQ on Onkyo) as well as 3 years of warranty (vice only 2 on Onkyo). Although you may want to consider the ATV 2 ($99) vice the Airplay upgrade ($49) as ATV 2 provides video streaming whereas the Airplay upgrade does not. Airplay upgrade also requires it to be played in all zones, ie. you can't use Airplay in Zone 2 while listening to other audio in the main zone ... whereas using ATV 2 will allow for this.
