I work in a large venue which has close to 1000 TV's. Last year we upgrade most of the tubes to LCD's. We also updated the satellite system to receive Directv HD using a Com1000 unit plus integrated the local cable feed SD and HD. With the cable providers assistance I went to each amp and balanced the rf signal through-out the building. I need to add 16-20 new TV's onto the system how will this affect the balancing and how do I determine what size taps would I need to install. I have 4 different levels I need to install these tv's 4 per level 2 per level off of the north vertical trunk and 2 per level off the south vertical trunk. Both trunks are fed off separate amps at the head end. Any thoughts!
