Originally Posted by
kryptonitewhite
when I have the mic set to 120 and I test, the metere barely moves... so I back it down to 110 but then the Check Levels fails. Back to 120 and Check Levels is green, 20db. back to 110, red Too High -9.x.
When i sweep now, master -20dB ( LOUD ) its lower than earlier
notnyt
Don't forget, once you have calibrated rew to the meter, if you change the dial setting on the meter, or the levels on your INPUT, you will have to recalibrate.
You can change the level on your receiver all you want.
Careful changing back and forth, it will alter your graphs. If you calibrate with the meter set to 120, then change the meter to 110, your readings in rew will read very high =]
And as others have mentioned, change the right side of the graph to either 200 or 100
Also, something amusing you can try to validate the results of the meter. I used my Audyssey mic for measurements to see how it was without any correction table, and it seemed to be very flat down to at least 10hz. You won't know the correct level, but it should at least help validate the fr curve.
