AVS › AVS Forum › Audio › DIY Speakers and Subs › "OMFG, Krypto is getting a mic finally!"
"OMFG, Krypto is getting a mic finally!" - Page 13
post #361 of 464
post #362 of 464
post #363 of 464
10Hz -3.6dB FS
THD: 7.70% THD+N: 7.75%
2nd: 5.74% 3rd: 5.11%
4th: .339% 5th:.363
6th: .228 7th: .129
8th: .032 9th: .0258
124.4dB
post #364 of 464
The mini screenshots are killing me
start -> run -> snipping tool.
Click the pull down on the right side of new, choose window snip. Click window snip. Then you can just grab the window you want. Go to imgur.com and upload it, post and be merry.
post #365 of 464
everything painful I do brings a new lesson... I am little grasshopper!
post #366 of 464
Also, with the THD window, you should make the limit lower so you can see what else is going on, something like 70db bottom end. How far is the mic from your speakers btw? good numbers. Sometimes I wish I didn't have to fight such a large room, but then I remember the large room lets me have a large screen and lots of speakers
post #367 of 464
The mic is about 7'3" from the TV and about 7'8" from the center of each tower... thats why I like having them so big, in fact how is this for WAF: I was getting desperate to cover shipping for the new subs and I tried to talk her into selling the IB3s and cutting the towers down! One of the reasons she said no was the bed would have to go too then, with everything taking up the entire room but doing it in a certain manner... it all fits, part of the experience
I am not finding snipping tool, via search, run, or in accessories, I googled it and it says I should have it (I have Vista) but I do not
post #368 of 464
look under accessories, or try running %windir%\\system32\\SnippingTool.exe
post #369 of 464
windows cannot find %windir%\\system32\\SnippingTool.exe
already checked under accessories, thats where google said it should b
post #370 of 464
What are you using for screenshots now? Just don't shrink them so much, and crop the important areas
post #371 of 464
print screen, paste in paint, cut the important part, repaste
I could zoom in, but it would get all nasty
post #372 of 464
print screen and paste shouldn't shrink the image. Are you shrinking them in photobucket?
post #373 of 464
thats a great poss, I'll set photobucket higher!
post #374 of 464
Looking better each time I pop my head in here. Good stuff!
Don't forget to list the odd order distortion.
post #375 of 464
how do I do that?
IDK what else to test either. now what?
post #376 of 464
Oh... I have no idea. At this point, you know REW better than I do. You had a list a few posts up that had all the even order distortion. You'd want to see it all. Even and odd. It's well documented that the 'odd' order stuff is the bad sounding distortion.
You got plenty more to test. Many configurations for your HT. I can't list everything...lol. Plus, there are other 'environments' to test as well.
post #377 of 464
What resolution is your desktop? If you are not shrinking them, maybe you are only running at 800x600? lol
Also, stop with the subs stuff, you need to build some new speakers.
post #378 of 464
My photobucket upload was set to 1024x768 (recommended), I tried Upload Best possible quality (while staying 1mb or less), then tried 2048x1536. REW sig gen only goes to 10Hz? I used NCH and did 5Hz but got weird results. No black spike, and the top says 15Hz -36.6dB FS, the circled window said 94.5dB. THD was just below 10%. My screen resolution is 1440X900, my monitor's max. Sure I wouldn't mind adding some tweeters to brighten up my sweet 14kHz on up, but I am more than happy with what I have for the mains.
2048x1536
post #379 of 464
perhaps rew rta only goes down to 10hz.
Also, you need to crop your images
Instead of photobucket, checkout imgur.com. It lets you upload stuff and if you check the edit box, you can crop the images as well.
post #380 of 464
alright Ill download then Im gonna redo 5Hz and try 6 Hz
BTW, my pics are gonna die in a bit anyway, just got my photobucket bandwidth exceeds notification
post #381 of 464
7hz is obviously way below your tuning point
use http://www.imgur.com it's free and there are no limits. Don't even need an account.
post #382 of 464
whoah now my whole screen is bigger
post #383 of 464
my desktop area is still 1440x900, but my internet is zoomed in.
that last pic was from imgur.com it was pretty easy to make a new account!
post #384 of 464
my window rattles in the track like mad, and everything else in the house, so IDK how much of this is feedback crap
post #385 of 464
Stop cropping in paint. Upload to imgur, click the edit box, then when the screen comes up, you can drag a box around the selection you want, and click crop. It's not hard
post #386 of 464
Why don't you just click the little camera in the upper left of the REW windows and save the files as a jpeg? It is a lot easier than doing screen shots.
post #387 of 464
It doesn't work that well for RTA. It doesn't seem to include the THD stats window.
post #388 of 464
Steps to quickly improve image quality with screenshots (the way you are currently working with mspaint.)
Hold down ALT and press the PrintScreen button
Howld down the windows key and type the letter R
The first time, type in mspaint (after that you can press enter)
Paste (ctrl+v)
right click anywhere on the pasted image and select crop, or press Ctrl+Shift+X
Save (ctrl+s)
type in the name of the file (ie screenshot1)
Press enter
close mspaint (Alt+F4)
(Using nothing but keystrokes, you can simply this entire method.)
alt+printscreen
Winkey+R
enter
ctrl+v
ctrl+shift+X
ctrl+s
screenshot1
enter
alt+F4
And there you go!
(Please do not press Alt+F4 while using any other application you would like to keep working with, the command it sends is "Close" and it will close whatever window or application you are working on without prompting you to save anything.)
Sorry, been at work all day, I had to make sure to make sure I was clear about that command.
Enjoy.
post #389 of 464
Kripto,
Looking good. It shows how a ported sub can extend 3-4hz below it's tuning in room with little distortion(under the 10% number). Of course you have 4 18's in a small room that helps a little.
post #390 of 464
Kripto,
Ah, there it is! Thanks MK!
