AVS › AVS Forum › Audio › DIY Speakers and Subs › How do I test resistance of speaker??
post #1 of 5
Hello. I just got 7 BIC America LH6 center channels (2 6 inch and a horn). They are super efficient but tooooo exagerated in the mid to high section IMO (between 2K to 5K), do not like that range. I want to change the X-over and cut at 5K to the horn and I thing it will sound sweet. I just ordered two high pass crossovers fro Parts express rated at 8 ohm. How do I know the ohm resistance value of each component inside the speaker. (there are 2 6 inch woofers and the horn). The total is 8ohm. Does it matter is the xover is 8 or 4 ohm?. confused here. Thanks for your help. I want to hear your opinion thanks
post #2 of 5
1. It does matter because the frequency will be off by as much as an octave if you use a network intended for 8ohms with drivers of 4ohms (or 16ohms).
2. But it is worse: The measured DC resistance is not what you need to know. You need to know the AC impedance in the crossover frequency range. You can measure the former with a multimeter but the latter requires an audio frequency measurement system as you will have to measure over the crossover frequency range.
3. Still worse: Because of the former and other factors, off-the-shelf crossovers are rarely effective and I doubt that replacing yours with this one is worth the bother.
You need to learn how crossovers work and then, perhaps, you can modify the one you have.
post #3 of 5
If you want to cut high frequencies, try adding 4-8 ohm resistor in series with one tweeter terminal. Should be a power resistor once you determine the value.
Even before that, just put your hand over the tweeter to confirm that the offending frequencies are coming from there.
post #4 of 5
+1, try a simple resistor 1st.
post #5 of 5
L-Pad, maybe? Give yourself some adjustability.
