Thanks for the explanation. My 65VT50 has 60hz, 48hz, and 96hz. I despise the soap opera effect and never use the motion smoother.Originally Posted by bd2003
Unless you're using frame interpolation/soap opera effect, 96hz playback of 24p is still 24 frames a second, its just displaying each frame 4 times, so there is no flicker. TVs display by default at 60hz, but 24 doesn't divide very well into that, so it doesn't look as smooth as it should. A display mode that is multiple of 24 solves that, some TVs can do 48 or 72.
Most games run at 30fps, 60 fps is butter smooth - its what cod runs at.
I told him to turn it off when watching a BR and he said ehh
:D
