AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Having problem with samson ex500 sub install
post #1 of 6
I have a pair of 4 year old samson ex500 subwoofers hooked up to a marantz reciever. i blew out the original woofers in the cabinet . i went online and purchased new woofers from carvin, the ps15-4's The right woofer works fine but the left is giving me a crackling sound. i thought it was a simple vibration problem or xlr problem but its not. any ideas on what the problem could be?
post #2 of 6
You're sure the wiring is correct and connected well?
post #3 of 6
thanks for your response. yes all is correct and connected well, i have installed many subs and speakers before so i know what im doing but i just cant seem to figure out what the problem is this time. maybe it's something simple that i overlooked.
post #4 of 6
How did you blow the woofers on the originals?
post #5 of 6
Sometimes subwoofers (or receivers) will make a cackling sound when 1+ capacitors is failing.
post #6 of 6
Thanks for your replies. One of the subs works fine. The other is cracking up.It sounded like a vibration from the cabinet but,it is more noticeable coming from the woofer itself. I will go through a trial and error i have a feeling it is the amp. It maybe the caps or a short some were.Any other ideas I Am all ears. thanks.
