Hey folks, over the next 1-2 years I want to slowly replace all my audio video gear. I have pretty much decided on the following
JVC RS40 projector + SMX AT screen
Datasat AP-20
Where I start to lose my mind is on the endless options of speakers. Back in my audiophile days (before RC Helis took over my life) I had auditioned a lot of high end speakers and I really don't think they offer what I am really looking for. So I have composed 4 options here that I was able to narrow it down to, my budget is anything under $20k for a 7.0 speaker setup (don't worry about the sub for now). So unless I am way off track here (feel free to say so, i won't take it personal) please give me your impressions of the following.
Option 1: DIY it ! Using the active XO options of the AP-20 I can actively filter 7 2way speakers. The speakers would be based around a JBL 2226H and some compression driver+horn to be named at a later date. This would be somthing similar to a 4-Pi speaker but done actively. I would then buy some used Bryston amps, I figure the older Bryston ST amps with 125-150w range would work well. This will be the cheapest option, but also has the potential to go the most wrong.
Option 2: Seaton Catalyst for the LCR and the sparks for the rear and surrounds. This option is more of a turn-key setup. They already have built-in amps so a direct from from the AP-20 to the speakers would make for a very clean setup.
Option 3: Genelec 1032A * 7 ..... no explanation needed here.
Option 4: Danley speakers + Bryston amps. I cannot for the life of me find the prices of the Danley range. The SH-50 will be out of my price range, but something like the SH-69 looks like a better fit for home use anyways.
The problem is i will be unable to audition any of these options so I basically have to buy them blind
Datasat AP-20
