I didn't get a reply to my 02-26 post, so I'm trying one more time with some clarification=>
The receiver appears to receive HDMI from the Comcast STB OK while in Demo mode -- I get STB audio from my 5.1 speakers that are connected to the receiver, DD indication on the receiver front panel, and so on. But my TV just says check cable. I'm using a high performance HDMI cable that works fine when connected directly between the STB and the same TV HDMI input. I've tried wiggling the HDMI cable on the back of the AVR while connected to the TV's HDMI input, but nothing changes. Is there something else I need to do to get the receiver to output HDMI?
I've noticed that the HDMI connectors don't seat very deeply on this AVR. Is this normal? With my other devices (TV, BD, STB, and Apple TV), the HDMI cable pushes all the way in such that the connector isn't exposed.
Either the AVR isn't outputting the HDMI signal properly, or there is some incompatibility with my 5 year old Samsung HL-S6767W.
Anyone out there using a Samsung HL-S6767W with this AVR successfully?
Any help would be most appreciated. Since it's too late to return the AVR to Newegg, I will have to try my luck with Pioneer Tech Support. Not looking forward to it.
